Potting/charging sequence
  • Potting/charging sequence
    Hi guys,
    I just finished winding my tele neck/bridge pups.
    I have my wax mix heating up and am wondering about the sequence for potting, charging, baseplate before or after potting/charging.
    Any suggestions?
    Bill
    http://www.canadianbreed.ca/
    http://www.canadianbreed.com/
    www.facebook.com/Canadianbreed
    www.youtube.com/user/Bobo9977
    Originally posted by Bill Scheltema View Post
    Hi guys,
    Any suggestions?
    Bill
    I've done it before and after with no discernible difference in tone. I don't have a gaussmeter, so I have no empirical evidence other than my ears. It's easier after because the magnets are attracted to the heating elements and each other in the wax pot, which can be a bit annoying.
    peace
    Shannon Hooge
    NorthStar Guitar
    northstarguitar.com
      I always charge after I pot. My potting tank is metal and I previously had a problem with the magnets sticking to the side and getting too hot causing shorts.
      Wimsatt Instruments
        Do you charge tele bridge pickups after you put the baseplate on, or before?
        I used to charge with it on, then I went to putting the plate on after...
          Hi
          I ended up charging after and also leaving the baseplate off as well.
          I found that the heat generated from soldering the ground lead caused the baseplate to stick to the softened wax.
          Bill
            Yea thats what I do. A little wax in between and the heat of the solder works well. I never trust a bare baseplate anymore because they just dont fit the flatwork flat enough.
              I usually charge the magnets even before assembly.
