Anyone have thoughts on how to cut keepers to length precisely? I've been cutting them on a bandsaw and grinding on a disc sander to length, but I don't like this method and too time consuming. Is there such a thing as a precision cut off saw?
precision keeper cutting....
Tags: None
Originally posted by Possum View PostAnyone have thoughts on how to cut keepers to length precisely? I've been cutting them on a bandsaw and grinding on a disc sander to length, but I don't like this method and too time consuming. Is there such a thing as a precision cut off saw?
http://music-electronics-forum.com/t17411/
The ideal machine is something like my little Barker mill, a small tabletop horizontal milling machine set up with a slotting saw blade. It'll cut off any kind of metal bars smoothly to length, within 0.001".
There are other ways too, using a small standard milling machine or mill/drill.
Remember, when cutting metal precisely, you want a slow speed and a sturdy frame, and a little bit of horsepower.
Well, cutting slugs is totally different, you're cutting something on a lathe, you can't do that with rectangular bar stock. I do have a small mill but its vertical.http://www.SDpickups.com
Stephens Design Pickups
Have them done for you and buy them 1000 at a time. There is no tonal art involved in drilling and cutting a keeper bar. Give a shop a sample and the metal specs. and have them make it. It is a dead simple part to make for a machine shop. Same goes for slugs. Gibson had the slugs made on an automatic screw machine anyway. Your time should be worth enough to make jobbing it out the best route.Last edited by JGundry; 05-15-2010, 03:52 PM.
Possum;
Round or rectangular doesn't make a lot of difference. My little Barker mill is what I used recently to make up a couple of batches of custom slugs for guys on this forum.
You can also certainly cut off rectangular bar stock in a lathe using either a four jaw chuck, a special collet, or a two jaw chuck with machined jaws.
If you've got a vertical mill, that'll work fine too. Set up a little fixture in the vise jaws with an end stop and support underneath the part, and trim the end of the keeper to length with an end mill.
There are lots of ways to do the job.
Originally posted by Possum View PostI've been cutting them on a bandsaw and grinding on a disc sander to length
I cut my blades on a large abrasive wheel cut off saw. I use a wooden stop block for different lengths. I push the piece to be cut up to the stop block. They all come put the exact length.
This saw leaves a burr that I have to get rid of, so I use a belt sander for that. The whole operation is quite quick.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
what about a metal hand shear?
Amazon.com: TD Industrial 5" Sheet Metal Shear Steel Aluminum Copper Hand…
Originally posted by StarryNight View Postwhat about a metal hand shear?
Amazon.com: TD Industrial 5" Sheet Metal Shear Steel Aluminum Copper Hand…It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I'll try the lathe but I would think the sharp corners hitting the cutoff blade would wreck the blade pretty quick.
We got some bolt cutters last nite, does a crappy job on keeper stock, I assume a hand shear would make a mess of the ends too.....http://www.SDpickups.com
Originally posted by Possum View PostI'll try the lathe but I would think the sharp corners hitting the cutoff blade would wreck the blade pretty quick.
For sure, but pretty much ALL vintage keepers were shear cut on the ends except maybe some earlier PAF keepers, and definitely ALL modern keepers are shear cut on all four sides, which is one reason they are so cheesy...http://www.SDpickups.com
Originally posted by Diablo View PostShearing adds cold work to the metal, and that will certainly impact magnetic properties.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Possum View PostFor sure, but pretty much ALL vintage keepers were shear cut on the ends except maybe some earlier PAF keepers, and definitely ALL modern keepers are shear cut on all four sides, which is one reason they are so cheesy...
But what does it matter? You don't see the thing.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David Schwab View PostHow so?
