Hi all, new member here. I appreciate any pointers from folks who've done this before.
I'm in the process of trying to learn how to build a winder. I'm gradually accumulating parts for both pickups and the winder.
I hesitated to prior to posting here, but I've looked through archives and all over the web but can't seem a vendor for several parts that seem central to the basic design. I'm trying to find a supplier - for lack of a better term - the basic "pulling - spinning - gearing - components" and the pieces that let you mount all that together.
things like,
- the steel rods (or whatever material they're made of - on a car it'd be the axle)
- belts
- pulleys (right term? - different size spools to set spin ratio between motor and shaft the pickup attaches to)
- bearings
- couplers (parts that squeeze onto the spinning shaft)
some of the parts I think I'm able to find here
https://www.surpluscenter.com/powerT...ame=powerTrans
but I'm thinking there's probably a pretty good one stop shop to get these types of assemblies so all the parts are compatible with sizes purchased.
And while I'm here, could I ask for advice on the size/speed of the motor? Based on everything I've read I think I'm wanting to get a DC motor so I can use the variable speed controllers, and this seems fairly doable at low cost, but I'm uncertain how powerful the motor should be.
Something like this variable speed DC motor all in one package seems like it might work well for me - assuming I can get the gearing ratios worked out (2:1 or 3:1 I guess?) and wiring seems simple enough , but feedback is appreciated.
https://www.surpluscenter.com/item.a...tname=electric
Failing that, is something like these motors overkill?
After seeing the small Schatten motor in some pics posted on this site, I wonder would these very low cost motors be too small to even consider or could they work?
Again, I greatly appreciate any feedback and tips. These type of things are very new to me (I'm more of a guitar player who can solder just a a bit) and I've spent the better part of this weekend and the last trying to educate myself - but I'm really ready to just start building the thing so I can do some winding! thanks in advance
things like,
- belts
- bearings
