I'm faced with making my own small humbucker (I'm very constrained on space) to help reduce 'EMI pickup' relating to a 'PIC bestowed' circuit board (with 4Mhz, 20khz clocks) that's going to be by necessity extremely close to the proposed humbucker.
This humbucker pickup will not be used passively, so I'm not worried about it's output level & therefore I can go much smaller than a traditional humbucker). In fact this proposed humbucker's signal won't even be heard - it's signal will be used into a PIC for deriving frequency/level of the string etc)
The PIC will be to one side of this proposed humbucker - just 2.5cm away , so I'm wondering which humbucker variant (if any) would yield the best EMI cancellation (for all the signal won't be heard, the less crud on the signal the better)....
1. Side by side (ie traditional) - probably not ideal, one coil would be significantly further away (relatively speakin) from the source of EMI (the PIC) & therefore not cancel well?
2. Stacked - possible - this would put the coils equidistant from the EMI source, but I've only about 8mm headroom to play with & it'd likely be tight to squeeze in two coils vertically - also, my initial attempts with stacked humbuckers weren't promising!
3. Split - this is the variant I'm leaning towards as I reckon it'd be the easiest to 'balance' wrt EMI cancellation (I've made myself a CNC winder so wrt to 'balancing coils', I can be accurate to 1/200th of a turn )
I'd be grateful for any thoughts, comments, tips, advice (eg whether the idea is dead in the water etc!)
