Originally posted by DrStrangelove
View Post
Slug manufacturer?
Originally posted by Joe Gwinn View PostThey might be a bit too hard magnetically, but it's probably worth a try, if one can get a small sample. Type 416 is widely used in forged marine fittings, so marine hardware stores (like West Marine) would be one possible source.
Bill Lawrence has quietly used ferritic stainless in the past and I recall posting some quick and dirty permeability tests of it on the old pickup forum.
There are a few ferritic stainless alloys specifically intended for solenoid cores in corrosive environments, types 430 and 446 in particular, but I mentioned 416 because it was easy to get and seemed inexpensive.He who moderates least moderates best.
Originally posted by DrStrangelove View PostBill Lawrence has quietly used ferritic stainless in the past...
I think Joe Barden uses stainless steel blades also.
I guess all the stainless I've been exposed to wasn't very magnetic.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
http://coneyislandguitars.com
Originally posted by David Schwab View PostI've read that the blades on his pickups were stainless. I have a broken one home I've been meaning to mess with.
If you poke around matweb.com, you can confirm that the type 400 stainless steels are magnetic. Type 300, 500, 600 aren't. Wikipedia has a good intro at
http://en.wikipedia.org/wiki/Stainless_steel
A search on "solenoid grade stainless steel" should hit pay dirt, bring up types 416 and 430FR from Carpenter Technology in Pennsylvania. www.cartech.com
Anyway, the idea is that you can polish stainless steels instead of nickel plate them.
--He who moderates least moderates best.
Originally posted by DrStrangelove View PostDoes it matter if they are hard magnetics (i.e., have a higher coercivity) than non-stainless steel? Hot rolled and/or annealed stock lessens this characteristic in most alloys.
There are pickups that use hex-socket cap screws for slug poles, and such screws are hardened.
Barden
Actually I read somewhere that he finall found his ideal blade steel on a state highway sign, not kidding either.....thought that stuff was aluminum?http://www.SDpickups.com
Stephens Design Pickups
Originally posted by Possum View PostActually I read somewhere that he finall found his ideal blade steel on a state highway sign, not kidding either.....thought that stuff was aluminum?
Use a cut-off grinder to cut this steel. A saw will fail.
Originally posted by David King View PostJoe that looks an awful lot like the steel strapping tape that comes in 1300 foot rolls in 4 widths for pennies a foot. A local packing supply house could give out samples or one could just look for a stack of old pallets on the side of the road and dig around in it.
Apparently the steel use in leg irons is perfect for the job.
Alternatively buy some electrical iron rods and turn them on a lathe. Make sure your parting tool is less than sharp and you'll get perfect bulls-eye slugs every time. Then of course buy a nickle plating kit from Micr Mark
http://www.ares-server.com/Ares/Ares...oduct&ID=83082
and you're away.sigpic Dyed in the wool
Originally posted by Spence View PostApparently the steel use in leg irons is perfect for the job.
and you're away.
The plating power supply looks a lot like a cheap little 6-volt wall wart with alligator clips. These can be had quite cheaply, and solutions can be had from Caswell: http://www.caswellplating.com/. For plating a bunch of small items, a wire basket containing the items immersed in plating solution and shaken as plating proceeds will be a lot faster. Naturally, it's called basket plating.
Originally posted by Joe Gwinn View PostActually, from some of the supply dramas we've heard, buying 3/16 mild steel rods from hardware stores and machining slugs from the rods on a cheap (~$400) small desktop lathe might not be such a bad idea.
You never have to worry about supply.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Well you might need to turn them to the correct diameter and cut them to length by parting them off. Also, you'll need to bevel the tops and bottoms.
How do you think they got that bullseye finish on the old PAf slugs ????sigpic Dyed in the wool
Originally posted by Zhangliqun View PostWhy would you need to put the rods on a lathe? Presumably they're already round enough -- or are they? Also, what would you use to cut the rods to length?
