Spent the last hour or so looking for P90 bobbins with 52mm pole spacing - Does anyone know of a supplier or indeed, if they're actually available.
P90 Bobbins - 52mm Pole spacing
Hi David, there are a couple of versions (easiest way to illustrate this is via the new StewMac P90 kits)
With either versions there needs to be a central section to the bobbin with threaded holes for the pole screws. I'm working on a project where these would be ideal if I could get hold of them with 52mm spacing rather than standard 50mm. I can make them myself from forbon with a drilled & tapped central block but was just wondering whether I could buy a number of them 'off the shelf'
Originally posted by copperheadroads View PostI dont think i have ever seen a P-90 with wider spacing than 50 mm
you could make them but then you need to find or make a cover with the right spacing as well
Looks like the keeper and the base-plate would be more of a problem than the cover but I can see why no one has bothered.
Two millimeters doesn't seem like it would be worth the effort but what do I know?
Thanks for your replies though, much appreciated.
