Here's a link to a series of web pages of mine, showing how I build the pickups for my basses. I cast my bobbins from polyurethane, and then overcast the pickups in black epoxy. You can see how I made up aluminum masters, silicone rubber molds, and do the casting. It's not real high tech. As the other guys have mentioned, the master can be made from almost anything, but it has to be made well. Any scratches and flaws will be precisely duplicated by the molding process.
Building Scroll Basses- Pickups 1
I don't currently use pressure or vacuum during my epoxy pours. With slow-curing epoxy mix and careful stirring and pouring technique, the bubbles can be dealt with. I also deliberately designed my pickups, with the perforated brass shells and ebony caps, so that most tiny bubble won't show. Also, black epoxy can be worked and finished after it's cured. So, if you get a bubble or flaw, you can actually repair it by dabbing in some more epoxy, letting it cure, then filing and polishing it to match.
