I made two strat single coil pups for a friend using 42 AWG formvar. A quick spec of them is one neck, one middle, overwound both based on his request, (approx 7.2k & 6.7k) alnico 5 staggered for a left-handed guitar, potted.
These were the second and third pickups I've done using formvar. The first one was just slightly less overwound and is in one of my strats. I found mine (first one wound) to be quite good. All of these pickups were replacing Texas Specials.
My friend says his have an almost chorus effect, especially when playing chords. I didn't notice this when he tried them out at my house. I am curious if anyone has had similar results or if this is a quality that formvar has. I am confident my wax potting is good and all the wiring is solid and correct. If he's not happy I'm not happy so I will probably be making him new ones using poly or plain enamel. However, I plan on using formvar more so I need to experiment more with it I suppose. I choose this design because he wanted an overwound hot pickup to push his amp. (although he states it doesn't really do that either!)
I have a feeling it may be something else other than the pickups but I'm not jumping to conclusions and am ready to except something is going on with them if that is the case. He's also using a Strat fitted with a tremolo bridge that has an extra spring to sort of make it a hard tail. I suggested first dampening the springs to make sure that may not be causing this sound.
Any ideas or insight? Maybe go with another alnico formula? Thanks!
