Just finished my first tele pickup set and I have a question. Do you pot them without the cover (neck pup) and the baseplate (bridge pup)? Or with?
potting tele pickups
Originally posted by spy View PostJust finished my first tele pickup set and I have a question. Do you pot them without the cover (neck pup) and the baseplate (bridge pup)? Or with?
Reason behind it is that you tend to have microphonics on teles, so the wax potting with the covers on helps insulate make everything rigid.
Make sure the screws only thread into the bridge baseplate and not the forbon.
If the forbon is threaded and the baseplate is threaded it breaks the wax seal when you thread into both, causing microphonics.
Good Luck,
Terry"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by spyThank you Terry!
About the neck cover, is it easy to clean it after the potting? Isn't hot enough?
I pot for 10 minutes each.
When you pull the P/Us out of the wax pot, let drip, then wipe off with a soft rag, or paper towell.
The chrome covers I used scratch real easy, so be careful handling them.
The bridge, I would do all the string wrapping before Potting.
It's real easy to break the start and finish wires so be careful.
Good luck,
Terry
