"I agree with whoever said “the wire doesn’t care if it’s machine wound or hand wound”. There is no mojo that makes pickups sound good just because you did it by hand. If you have a machine that makes an exact replica of a pickup that was hand wound then it would sound exactly the same. I know that I would never make a machine that could that, but if somebody else thinks they have created something that gets the hand wound sound, and if their customers think that the pickups have a hand wound sound, then who are we to say that they didn’t succeed? "
The wire doesn't care? Neither do any of the other components. This is a typically diabolical response to physical reality. No disrespect but it's just a meaningless answer to a question that requires a scientific answer.
The sum of the component parts is the bulk of what makes a PAF sound like it does. Maybe handwinding a PAF with a so-called scatter pattern will not have as much effect as it does on a Strat bobbin because of the limited traverse but I believe that the difference will be significant in allowing the pickup more openness than machinewound. in any case, unless you were present at the Gibson factory when PAFs were made, you can only really rely on other people's accounts whether they be right or wrong. It's a bit of a pointless argument. Best just get on and make your PAFs to your own special recipe and stop talking bollocks about it....especially those who don't make humbuckers. Never mind how good your ears are; that's your opinion anyway, not everyone else's.
Perhaps, those of us who can, will post some sound clips on the new Les Paul Forum as Possum has suggested. Personally, I don't have a way of doing that yet.
