Originally posted by David Schwab
View Post
Fiber flatwork vs plastic bobbin.
Originally posted by Mike Sulzer View PostBut the tail cannot wag the dog very much. In this case the tail is the winding capacitance and the dog is the cable capacitance. The latter is a lot bigger, and although changes in the former can make a difference, it is not very big.
The inductance changes due to altering the shape of the winding are more important. There is no other larger inductance around, and the arrangement of the winding has a significant effect on the flux coupling.
Also I think of something about the flatter coil sounding warmer, more towards the humbucking pup. I think when the coil is flat, the outer turns has a bigger area inside, so the window of sensing the strings is broader eg. it sense a 1/2" section of the string instead of the a very narrow window where you sense maybe 1/8" section of the string. Some the wider coil sense more harmonics like the humbuckers than the narrow coil of the strats.
Originally posted by Alan0354 View PostI actually gave quite a bit of thoughts about your comment. I do agree about the increase of inductance because of the bigger area inside the turn. One thing I do want to point out, the inner winding capacitance might be more important than you think. The reason is you know for sure the winding pattern make a big difference to the sound. Scattered winding lower the capacitance and it sound glassier and brighter. So the capacitance do contribute to the sound.
As for the sampling region, a flatter coils does not sample a wider window. As far as a measurements goes, the size of the sampling region is one of the results of the discussion on sc versus humbucker string sampling. The theoretical reasons are:
1. The magnetization of the string is primarily right over the pole piece. The "vertical" component falls off very quickly away from there.
2. The pole piece guides the flux from the vibrating string down through it. Narrow loops and wider loops enclose essentially the same flux until the loop gets so large that it also encloses returning flux lines. (Such wide loops contribute less output.)
Originally posted by Mike Sulzer View PostI will stand by my statement about the capacitance unless proven differently. Also for the inductance, it is not just the bigger area of the loop, it is the close coupling in flat, rather than tall, coils with the same number of turns.
Maybe we can take a poll of everyone here that winds single coils.
Do you use Forbon Flatwork with rod magnets, or do you use Plastic Bobbins with rod magnets?
We all can buy both, so What do you use?
BigT uses forbon Flatwork with Rod Magnets.
What do you use?
Terry"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by Alan0354 View PostWell, then how do you explain the different sound with different winding pattern? Given the dimension of the bobbin is fixed, the only thing you can change is the inter winding capacistance.
Originally posted by big_teee View PostMaybe we can take a poll of everyone here that winds single coils.
What do you use?
Terry
Originally posted by Alan0354 View PostThe point is the mass public have the idea the fiber flatwork sounds better and all good pups have to use fiber flatwork. They also sneeze on Fender MIA pups and Tex Mex as cheap pups. I personally prefer the plastic MIA sound over the Fender CS54 I have. Also the biggest motivation point of the plastic bobbin is the ability to adjust the stagger without worrying about ruining the wires.
One difference between forbon and plastic that I failed to mention before - if you are leaving pickups unpotted (and maybe if you wax pot them as well, I'm not sure) there can be a very small difference in how the microphonics behave. I've run into this using phenolics of various kinds. Tap a sheet and you hear this kinda annoying high sound. Wind a pickup and install it and then tap the pickup, and you'll hear the same sound through the amp. Forbon has a quite dull tone. I'm not sure that I'd ever let that be the deciding factor in choosing materials for my own pickups, but if I had a desire to sell them unpotted I would certainly consider it.
Originally posted by Mike Sulzer View PostSuppose the two coils of a humbucker in series have 80 pf of capacitance, and the cable has 500 pf. Suppose you double the series coil capacitance to 160 pf by winding differently. The change in resonant frequency is sqrt((500 + 80)/(500 + 160)) = .937. This is about 6.25%. Audible sure; large effect, hardly. Using different cables can make more of a difference.
Originally posted by FunkyKikuchiyo View PostAgain, I'm just not seeing these voodoo beliefs in the market, and I deal with players/gearheads on a regular basis. There are many other differences between vintage style pickups and the "modern" style as made by Fender, not least of which is that many of the ones that come to mind have ceramic magnets. I'm yet to have a single person say to me that they believe (or read somewhere) that forbon as a material was superior to plastic. It is only really mentioned as an indication for being vintage accurate.
Originally posted by copperheadroads View PostThe main difference between a forbon & plastic bobbin strat pickup is distance between the wire & the magnets
If you cut a plastic bobbin in two to separate the top & the bottom ,You will see there is quite a bit of plastic ,Compared to tape or a coat of lacquer like on a traditional style bobbin
The main difference in tone is the forbon style pup will be more dynamic in every way .I find that plastic bobbin pickups sound a little bland
The part of the magnet between the poles doesn't have anything interesting going on. The strings are redirecting the flow of flux from the poles through the coil.
So it's not like having the windings touching the magnets makes the pickup any more sensitive or anything.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
http://coneyislandguitars.com
Originally posted by David Schwab View PostBut it doesn't matter if the wire is touching the magnets in this manner. Maybe the only thing it will change is the capacitance of the coil's inner windings.
Is how you can vary the height of the bobbin, and the fact that you can get more wire on the bobbin and still get the cover on it.
The plastic bobbins that are available, have very limited Winding space.
You have so many more variables with Flatwork.
Terry
Alan, may I suggest you start winding some pickups? Winding might put this in perspective for you. Many things you read may not jibe with what you have been taught in your University. Some of I may be pure myth and much of it may be due to misinterpretation of why and what actually makes a particular pickup sound great and feel great. But, I don't think it matters if you are a luthier became winder or an engineer that has become a winder. In the end it has to sound good. An amazing pickup may only be a few percent different from a good one. Most guitarists will gladly pay for less than a decibel in the direction they want to go, or for less than 100Hz in the direction they want.
Winding pickups is not just a science, it's an art. I don't brag much because most of the guys here wind some REALLY good sounding pickups. Plastic is crap. Don't develop your art winding on crap. Sure, it could be done. But... It will look really cheap, and the guys have already given you enough reasons not to do it!
Stephen Conner is a really smart engineer. He is also helpful and his contributions are very respectful! Mike Sulzer is also smart and I think he might be an engineer too. Oh well, before you get yourself in trouble, wind some pickups! After you have wound a few, I'll tell you how to wind a humbucker that feels like a tone zone but isn't so dark for your les Paul. But, keep in mind I am a bartender... I probably don't know anything
Ethan
