Good day everyone,
I need assitance with some pickups and was pointed in this direction as the best resource for help.
I've got a pair of gold foils that I over paid for (shocking isn't it, darn you ebay) that are in need of a major overhaul. The guitar they were in was greatly abused and these showed up at my door full of rust. The covers are fair but I'll not be using them. The coils are intact however the paper wrapper is destroyed. The magnets are in about 100 pieces. The cores were rusty but I was able to save them and was also able to remove the pole screws.The base plates are junk and won't be reused.
Where I'm at now. I'm using one of these on a build. I made a new bobbin out of some heavy paper and slipped it inside the coil and then wrapped the coil with some heavy tape. Not the best situation but it seems to work. I placed the wrapped coil on the core and soldered it up with some new leads. Then I constructed a wooden cover and installed some new longer pole screws. Here's a couple of pictures of the pickups current condition.
Now for the help. Firstly, I need magnets. These were 1/4" x 1/4" x 2 1/4" ceramic magnets. I found a source that I have not been in contact with as of yet. They have 1/4" x 1/4" x3" ceramic 5 and the same in alnico 5. Would either of these be a good fit material wise and would one be better than the other?
Secondly, the coil is wound ccw. This is going in a Tele with a standard bridge pickup. Should I flip the coil to be wound clockwise? Should I install the magnets north up or south up?
Thank you very much for any assistance you can offer.
Steve
Steve
