i just wound a pickup last night and took a few photos of the setup including the paper funnel system i used to prevent missing the bobbin while winding.
here are a few pics.
here you can see the pickup on my metal lathe (bit overpowered for pickups maybe?). you can also see the reedswitch connected to the calculator to cound the turns. the paper funnel system is there aswell letting you see how it directs stray coils back into the bobbin. you might notice the paper behind the bed of the lathe, which i put there to make it easier to see the wire against the background.
there is the coil i just wound. i have decided i will call it the gravity coil, as it is wound 1000 times the acceleration due to gravity on earth. i was about to stop at 9800 and went the extra 10 just so i could say that.
here is the lathe itself. it works well to wind, i just put 2 milkcrates ontop of eachother and sit on them while winding, and put some music on til its done.
my spool of wire. 0.06 mm (between 42 and 43 awg, got the odd sizing as it was the smallest spook they had at 1.6kg as opposed to 4 kg ones)
one question i have, is it bad to have a group of lose wires that you can move by hand? i glued 2 pieces of paper together for the funnel system to make them mroe rigid as i want to be able to put the pieces into a walnut cover that i will make. i want to keep the unit fairly thin so i used just paper, and it will get its real stiffness in the cover. the glued piece came in a bit and funneled in a few mm from the edge of the bobbin making a line where they stopped but they would slip into the gap and loosen up. i know i will have to do some potting, but other than some light potting (dont want to fully remove microphonics) would i have to do something else? does it do anything bad?
thanks
thanks
