Originally posted by Mike Sulzer
View Post
1955 P90 muddy - defect insulation?
Originally posted by JGundry View PostBefore you slice the wire off the bobbin weigh it without screws, unwind to determine the turn per layer and also read the outer diameter of the wire with a micrometer, then take 10 feet of the wire by wrapping around a one foot ruler 5 times and take an ohms reading and divide by 10 to get an ohms per foot. If you want to keep the tone as true to original as possible use the above info for the rewind.
Before you do a rewind, keep in mind that the thickness of the insulation will affect the size of the coil, hence the tone. Gibson probably used Heavy Formvar wire back then, which may be thicker than PE, or poly wire. Not sure what happens with Formvar, but Poly insulation stretches around the corners, increasing capacitance. PE doesn't stretch, but requires a heat treatment process after winding to patch cracks on the edges. You may actually get the best results with PE wire, if you follow proper post wind heating method. There's also the matter of annealing, which makes the wire both more brittle and more consistent. Check into that.
No matter what you do, you wouldn't likely get the same results as the original wind. No two pickups are quite the same, anyway. Now you have a P90 chassis. You're free to experiment. You might want to wind lower for more highs, or use thicker wire for more of a "woody" mid emphasis, or use thinner wire for better clarity and smoother highs. I think 42awg is the standard, but go for whatever whatever appeals to you.
I never heard of Gibson using heavy Formvar. Fender sure liked it though.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Mike Sulzer View PostThe skin depth of copper at 10 KHz is a bit under a mm. #42 wire is something like .05 mm in dia. I do not think skin effect is an issue, period.
How is he going to measure the capacitance? Not going to get an accurate reading with a normal meter.
Micro cracks causing eddy currents? Stupidest thing I have ever heard.
You are offering advice on things you know nothing about. Your advice is best ignored.
Yeah, he won't get an accurate C measurement with a normal meter, but it can be done with the right equipment and technique.
Eddy current shorts from micro-cracks on PE wire insulation are indeed a possible cause of the problem. I am not an engineer, but have done a fair amount of research on the subject over many years. I have also had the privilege of having many discussions with legendary pickup designer Bill Lawrence (a.k.a.Willi Lorenz Stich). He was the one who explained about eddy-currents from micro-cracks. He has a method to pinpoint and measure them, and even taught Abigal Ybarro about the correct wire treatment process to avoid them.
There may be more going on in pickup tech than meets the eye. Please refrain from personal verbal attacks in future, sir.Last edited by Fluoroscope 5000; 10-26-2012, 05:12 AM.
Originally posted by Fluoroscope 5000 View PostNo matter what you do, you wouldn't likely get the same results as the original wind. No two pickups are quite the same, anyway. Now you have a P90 chassis. You're free to experiment. You might want to wind lower for more highs, or use thicker wire for more of a "woody" mid emphasis, or use thinner wire for better clarity and smoother highs. I think 42awg is the standard, but go for whatever whatever appeals to you.
Originally posted by Fluoroscope 5000 View PostI don't know a lot of the history of this stuff, just speculating. If they used PE, that would more likely indicate a problem, since proper post winding heating technique may have not been used. Isn't it likely that the lacquer used in PE might break down over 50 years? I'd think so.
What would be the proper post winding heating technique for PE?
The lacquer might look relatively new, but I'd wonder what kinds of chemical changes take place that might affect it's insulating properties, or even cause corrosive interaction with the copper? I honestly don't know, but it bears some research.
Proper PE wire post-wind treatment involves heating to 256 F within a few hours of winding. It must be at least that temp, but not too high to melt the lacquer. It was apparently in the original instructions with the wire and was a commonly employed practice by Fender that may well have been compromised as a cost cutting measure during the CBS era. Enamel is actually an incorrect term to use. Enamel is very brittle and can't be used as wire insulation. PE is a lacquer.Last edited by Fluoroscope 5000; 10-26-2012, 01:36 PM.
I think the most likely explanation is just plain shorted turns. Never heard of "micro-cracks" either.
Nor did I ever hear of baking plain enamel wire at "256" (256 what?) Maybe it was done in old transformers and motors, but I thought that was to speed up drying of the varnish they were commonly dipped in, and drive any remaining moisture out of the kraft paper used as inter-layer insulation. I think the heat might be too much for plastic pickup bobbins."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
Originally posted by Fluoroscope 5000 View PostYou're right about the skin affect not likely being an issue, but if the copper near the surface is much higher resistance than the rest of the wire, there could be significant phase differences in signals traveling closer to the surface, wrong?
Originally posted by Fluoroscope 5000 View PostYeah, he won't get an accurate C measurement with a normal meter, but it can be done with the right equipment and technique.
Originally posted by Fluoroscope 5000 View PostEddy current shorts from micro-cracks on PE wire insulation are indeed a possible cause of the problem...
Originally posted by Fluoroscope 5000 View PostThere may be more going on in pickup tech than meets the eye. Please refrain from personal verbal attacks in future, sir.
I don't know why I originally referred to them as micro-cracks. It's just cracks in the insulation at the bobbin ends. It's one possible cause of frequency loss. That's why I mentioned it, and to encourage proper procedure for PE wire. I meant to write 256 F/125 C. Bill Lawrence told me about the issue and the heating process. He knew Leo Fender back in the 60's, and was chief engineer at Gibson in the 70's. Abigal Ybarro told him that Fender changed/discarded the process when they started using plastic bobbins. It is too hot for the plastic. Don't know when they started using poly wire, but it's not required for that.
Obviously, we didn't have a verbal exchange. Not sure why I added that word. I think I may have been flustered by the hostile nature of your remarks, and I posted in haste. No, I'm not a delusional paranoid...nor a vindictive dick. Fair enough? Making a blanket statement that someone doesn't know what they are talking about, and that their comments should be ignored appears as a thinly-vialed attack on someone's character. I don't really give a hoot what you think of me, but I do wish you would refrain from making such comments in future...like the last insinuation you made. It's just unnecessarily inflammatory, and disconcerting to see when I'm trying to offer real world possible explanations for a problem.
Moving on -- maybe surface corrosion has no effect on phase. I don't know. If you want to find out more about that, and how insulation cracks can cause eddy currents, call Bill Lawrence and ask for an explanation. I don't know enough to prove it one way, or another. He has tested many vintage pickups and found the evidence. He even has a proprietary method for pinpointing them.
Originally posted by Steve Conner View PostMaybe it was done in old transformers and motors, but I thought that was to speed up drying of the varnish they were commonly dipped in, and drive any remaining moisture out of the kraft paper used as inter-layer insulation. I think the heat might be too much for plastic pickup bobbins.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Fluoroscope 5000 View Postcall Bill Lawrence and ask for an explanation. I don't know enough to prove it one way, or another. He has tested many vintage pickups and found the evidence. He even has a proprietary method for pinpointing them.
But that has nothing to do with phase cancellation or eddy currents. A closed loop around the coil will cause issues due to eddy currents though. Maybe that's what you are thinking of?It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
