With the prices for vintage above $500.00 it seams strange there are no offerings.
Why does no one make a floating DeArmond copy?
That may be because, while there is a modest market for archtops, the majority will be designed around pickups pre-installed into the top.
I think it is also fair to say that floating pickups anticipate a certain amount of clearance between body and strings; something which can't always be guaranteed.
So, in many respects, while your assumption is largely correct that things which command high prices also identify a market, it's a bit of a business risk, which I imagine someone would only undertake as a pure labour of love, rather than as a revenue stream.
There are the Kent Armstrong and Benedetto floating pickups. But no one makes a monkey on a stick.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I have a 1937 Kalamazoo KG-21 that, unfortunately does not have sufficient space between strings and body to mount any commercially available pickup in (it's about 1/4-3/8" clearance). I've attempted to wind my own, using some very small neodymiums, but I used the wrong adhesive and the structure cracked. The bobbin was two pieces of credit-card thin PCB board, with the flatwork and magnets held in place (well...for a little while) with cyanoacrylate. I'll have to try again with a different adhesive, because I am NOT cutting a hole in the top and I am not going to get the sound I want with a piezo bridge.
There are some copies made in Germany but I can never remember the guys name. These are from Finland and very nice too.
Floating single coil pickup for archtop guitar :: SWINGMASTER
I did a 4 string tenor floating pickup a few years back. I can't say anyone beat a path to my door after that escapade. My suspicion is that each guitar would need a custom application. Lace/Actodyne were doing custom low impedance pickups with transformers for a while. I'm not sure if they still do. Those things were about 1/8" thick except the bump at the end for the xformer. I think a balanced, low impedance pickup that could feed a desk or mic preamp would be a reasonable option but archtop players are all pretty set in their ways.
Wow that swingmaster is the real deal.
Originally posted by jonson View PostThere are some copies made in Germany but I can never remember the guys name. These are from Finland and very nice too.
Floating single coil pickup for archtop guitar :: SWINGMASTERIt would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Mark Hammer View PostI have a 1937 Kalamazoo KG-21 that, unfortunately does not have sufficient space between strings and body to mount any commercially available pickup in (it's about 1/4-3/8" clearance). I've attempted to wind my own, using some very small neodymiums, but I used the wrong adhesive and the structure cracked. The bobbin was two pieces of credit-card thin PCB board, with the flatwork and magnets held in place (well...for a little while) with cyanoacrylate. I'll have to try again with a different adhesive, because I am NOT cutting a hole in the top and I am not going to get the sound I want with a piezo bridge.
* WD Music Products - SLIMBUCKER SIDE MOUNT JAZZ PICKUP CHROME
he also makes a Dobro pickup that's 7mm thick:
kent armstrong pick-upsIt would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
My Dearmond copies are only 1/4 inch thick but I do not sell them. These are good.
Welcome to Jazz-Guitar.com
Originally posted by David King View PostThose nice looking Statler pickups are 10.3 mm thick which is .4" -a shade over 3/8".
Kent makes a decent pickup. Unfortunately, I have maybe 3/8" between the string and body, Some of that space would need to be between the surface of the pickup and the string, leaving 1/4 or less (likely less) for the actual pickup itself. The neodymiums I'm using are 1/10" thick and 1/4" in diameter. The total height of the magnet, flatwork, and glue was (and will need to be) somewhere in the vicinity of 3/16", if that much. Apart from getting the right adhesive, another big challenge is winding a coil that slender/short without precision equipment.
