I have this P Bass PU on my table and just wonder how weak its Magnets are. It reads at appx. 700 Gauss. Was this part of the concept or did they usually use fully charged A 5 magnets at 100 - 1200 Gauss?
Early 70ies P Bass magnet charge
So if they orig. came at 7-800 Gauss, how would they change in sound if I would succeed in recharging them up to 1000 i. e.? Would they possibly sound too trebly? I have already rewound them w. 0.42 HFW because I don#t have the PE stuff in this gauge. That alone might give them a boost in treble. I'm a little concerned that they would turn out too sharp as one of the bobbins couldn't take too many turns because of eccentric issues. Staying at the same number of turns the overall output is at 10 KOhms which might add to the suspected sharpness. I dunno if those factors, low number of turns, HFW wire and a possibly higher gauss would bring out too much sharpness or if I'm just a little paranoid. I don't have the P Bass at my home, neither a test mule, so I feel like shooting blind. If the guy i<#m doing it for don't like it I'll redo the job w. poly. I hope they turn out fine.
But again, is it a good idea too pump up the gauss (if possible)?
I think self de-Gaussing is likely. The rule of thumb is a minimum ratio of 3:1- 5:1 length:diameter for Alnico rods to maintain a charge. The Gauss strength is going to have a "half-life" where it will drop quickly at first and then exponentially more slowly over time.
Music man magnets break that rule and seem to get away with it so it's not hard and fast.
Originally posted by Telemachos View PostSo if they orig. came at 7-800 Gauss, how would they change in sound if I would succeed in recharging them up to 1000 i. e.? Would they possibly sound too trebly?
There always seem to be some kind of myth that a P bass is very deep with no high end. That's just the tone people used to use, but not how the bass naturally sounds.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I wish I could answer your question. I don't have a test mule so I'm dependent on what the bass player will report after installation. He sent the PU from a city 400 miles away from here. My assumption is that it will possibly sound weaker and w. more chime in the upper mids and highs. The guy told me that he is satisfied w. the std. series wiring and don't sees any need to s.th. different, but that it would represent a nice to have option once he decides to go with some switching pot. BTW I wound it RW, RP wise.
Originally posted by David King View PostTelemachos,
Could you hear a difference between series and parallel?
I have series parallel switches on my P/J bass with DiMarzio pickups.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
