Originally posted by Mike Sulzer
View Post
See for instance Eli Brookner's cover page article in Volume 252, Issue 2 (February 1985) of Scientific American.
Mars is different because it rotates faster. That is what causes the overspreading. Venus, for example rotates much slower, as does Mercury.
You are ignoring what I said about codes in responding to your statement about code105.
Which statement did I ignore?
Windowing: the six(x)/x is only a significant problem when there are narrow spectral lines.
coherent integration: The cross spectral analysis used here takes the product computed between the ffts of the two inputs. It might be possible to use a combination of coherent and incoherent integration, but I do not think that the added complexity is worth the trouble.
