LR Baggs m1a
I found a pic of the cutaway of the pickup.
http://www.lrbaggs.com/sites/default...kup-slide4.jpg
Looks like maybe a Neo Bar goes inside of it?
I take it your magnet is missing?
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
If you had a magnet on each side, you would want them head to head.
Like North/screws/North.
That would make it like a P90.
Then the coil on the bottom would probably be a dummy coil, for hum canceling.
If you have some magnets laying around, or even some rubber refrigerator magnets to test it with?
I would think ceramic magnets would work good."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
I'd contact LR Bags directly and see if they can send you a couple of the magnets. They may be having them made in China and may not have any of the magnets available.
You could also just measure the spaces and order similar magnets in grade N35 Neodymium from KJ Magnetics. It's probably something like this:
K&J Magnetics: BX844
or this:
K&J Magnetics: BY044
I agree that a ceramic magnet would probably work fine though you might not like the tone of that either.
Start with the dimensions (which might be metric) and do a search. Ebay is a good possibility.
The coil on th bottom indeed is for canceling huming and it's also vibrating so the pickup is sensitive to the body's resonance. it's awesome and I never met any pickup witch can do the same (I know some of the piezo can do this). And its also cost more than my monthly income... thats why I want to bring it back to life so bad.
Spaces dimensions: 60 x 6 x 4 mm
Why ceramic? On other forums people says that neodymium would be better
Ceramic is easier to trim if you can't find the exact dimension you need.
The closest neo I could find was 30mm x 5mm x 3mm in N50. It's not perfect but 4 of them will get your pickup working again.
10x Small Strong Block Cuboid Magnet 30mm x 5mm x 3mm RARE Earth Neodymium N50 | eBay
Originally posted by Tio View PostThank you very much, I'll buy it for the next payment
You need the magnet gauss toward the screws.
GL,
Terry
