alnico treatments....
    Originally posted by Possum View Post
    yeah you gotta heat it to 1000 degrees farenheit, they will lose their magnetic charge and will need to be recharged afterwards, let me know how it goes....
    The kiln isn't up and running yet, but I'll definitely post some info when I get time after it's ready.
    int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
    www.ozbassforum.com
      For Alnico the Curie Point is around 1,472° F or 800° C. Freakin' hot! Alnico has one of the highest Curie Points.
        wow...
        that IS high, most kilns won't hit that high, I think my casting kiln would go to 1200 degrees, 1500 is scary hot....
        http://www.SDpickups.com
        Stephens Design Pickups
          Yep, that's a high temperature. The kiln I'll be using can go up to 1000° C, so no problem there.
          www.ozbassforum.com
            Originally posted by Dr. Guitar View Post
            So let's say you had a fully charged magnet, but it was a little bright. Push North and North together to take away some of that charge, and it should mellow out a little?
            Basically, yes. I prefer to use a stronger magnet against the magnet I'm degaussing, typically an A8 on an A5.
              deguassing
              But does it actually warm up the sound or just reduce the output?
              www.ozbassforum.com
                depends....
                It depends on what pickup you're doing it to, on humbuckers it does warm up the sound, on a heavy formvar strat bridge pickup it does nothing discernible to my ears. The benefit of doing it on a strat is to reduce stratitis and get a little more sustain as a result.
                  Yes, I needed to do that on a strat set a while ago and did based on your suggestion back then.
                  So, one issue is the harshness of the bridge pickup in a strat set. I mostly wind bass pickups: single coils, dual coil humbuckers. So, whether there is a great benefit to warrant a warmer sound there I don't know yet, still testing.
                  www.ozbassforum.com
