I've been mulling this over in my mind and may do an experiment to see what the results might.
So you have two identical pickups, say a P90. Both wound to 8K.
One uses a wide random scatter, fewer turns per layer.
The other uses more turns per layer and less scattering.
WHICH ONE HAS MORE OUTPUT?
At its simplest, say you have a coil with 8 turns on it.
One has 4 turns on each layer.
The other has 2 turns on one layer and 6 turns on the other, which coil has higher output voltage?
