Wiring for coil split with vintage wire
  • Wiring for coil split with vintage wire
    How would you wire a humbucker for coil split using vintage single conductor braided wire and a second single conductor wire?
    www.guitarforcepickups.com
    I believe you would connect the second single wire to the series connection of the pup. Grounding that connection would cut off the coil associated with ground.
    -Stan
    ...just transferring wire from one spool to another
    Stan Hinesley Pickups
    FaceBook
      I had a set of Gibson Dirtyfingers that used vintage braided coax, and then had a second braided coax that was connected to the series link.
        I"ve seen that alot in 70's pickups that were rewired like that for coil splitting, good point....
        http://www.SDpickups.com
        Stephens Design Pickups
          Personally I'd just use 4-conductor cable. It would be less work, and offers more choices for wiring the pickup.
