Summer Fund Drive:C'mon guys lets show some support! If this site has helped you an you haven't recently donated Include your username so I know whos donatingPlease consider making a donation. :)
That was coil hight (.252"). I read .257" for the center post on the screw and .259" on the slug.
Hello,
after reading all those post I wonder wich effect on the tone will happen wehn routing the centershaft of a bobbin and chance the coil dimension ?
Hello,
best
David
Heh. I tried that once. If you have a decent setup I suppose you could do it. I made an awful mess of a couple of bobbins. I know some folks here have split them to add spacers to make taller bobbins, etc.
