Wide Range Mag Thread Size
  • Wide Range Mag Thread Size
    Got a guy wanting some Wide Ranges. What is the thread size of the screw-in magnets?
    i believe they are Size0.182”x 0.688” M5 x 0.8 Threaded
      Sensmag just sent me samples of these. Package says 10-32 x 0.625. But measuring them they are smaller? I 'm measuring them as .182" or 4.6mm x .63" or 15.87mm.Click image for larger version
        Probably metric M5 threads. Is it FeCrCo material?
        https://www.philadelphialuthiertools...ngth-set-of-6/
          I was wondering what the originals are.
            While you didn't answer my question, I will answer your's: Original widerange magnet material was CuNiFe, a much softer alloy than AlNiCo which allowed threading with conventional tools. Doesn't seem to be available anymore.
              The OP is asking about thread size/pitch, not the metallurgy of the magnets.
              -Brad
              ClassicAmplification.com
                Thanks Mozz for posting the dimensions for the sensmag product -- I have been trying to choose magnets for a similar application.* I read that they make these in AlNiCo 2, and 6. If that is correct, which grade are these? Do you have any idea if they will sell small quantities, or what they would cost?
                * https://music-electronics-forum.com/...nces-with-this
                  They are not cheap & each magnet cost about the same price as an Alnico bar magnet .
                    Thanks. I suppose they must be individually machined with some astoundingly hard tooling...
                      I'd be a little surprised if Fender used metric threads anywhere in the 70's. The 10-32 sounds about right for a .1875" dia but not at all surprised that the finished dia would be .182". However the M5 threads should be closer to .190"
                        D5*16mm,FeCrCo44/4 similar to Alnico5
                        FeCrCo12/2 grade similar to Alnico2
                          What is the reversible or recoil permeability of these magnet materials?
                          The larger the number, the higher PU sensitivity.
