Originally posted by Stratz
View Post
Daily Run Down, & Round Table-P/Us
This topic is closed.
www.sonnywalton.com
Originally posted by SonnyW View PostMight try a .033, I do that sometimes. The cap makes such a big difference.
I also need to wire it so the tone pots actually work for more than just the last 10% of the wiper.
Hi Guys:
I like the .033uf also.
Depends on the pickups and guitar.
I have had good luck going to the switch with 4 wire shielded Mojo pickup wire.
So I guess that one wires from the Jack to the Pots, then to the switch.
I guess the pickups go to the switch?
I have a similar guitar but it has a 5 way in the control cav.
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by Stratz View PostDo you really hear that much difference between a .033 and a .047? I don't think Ive ever used a .033 on anything. As lousy as the cheapo Duncan Designed pickups sounded (and they are cheap, you can bend the entire humbucker as there's no fence on the base plate and it's really thin as well so it's very flexible) I did find a sweet spot with the tone rolled off just a touch. I guess I'll just have to try a bunch of different caps, maybe make an external hookup for testing until I find the one I like. I need to pick up some good quality caps
I suggested .033 because it is about halfway in between .022 and .047, (and I have a lot of them ) I can hear more difference between .022 and .033 than I can between .033 and .047 but there is a little. When I said big difference I was mainly talking about the cap value overall, not this particular case.
I did just try it in my test strat which happened to have mini blade baby buckers in the neck and in the bridge, kind of similar in a way to what you have. I didn't have to install anything, just move the clips around. I could definitely hear more difference on the neck position than on the bridge. I used the aligator clips and played the same chords each time, switching from .022 to .033 to .047uF. The only place I couldn't hear much change was on the .033 vs .047 on the bridge. But on the neck it was there.www.sonnywalton.com
Originally posted by SonnyW View PostI suggested .033 because it is about halfway in between .022 and .047, (and I have a lot of them ) I can hear more difference between .022 and .033 than I can between .033 and .047 but there is a little. When I said big difference I was mainly talking about the cap value overall, not this particular case.
I use a .022, or a .033 on the neck, and a .047 on the bridge usually.
The 2 tones gives more flexibility.
Speaking of Caps, what is the History Sonny, on the big flat Vintage Caps you have?
Terry
Originally posted by big_teee View PostThat's what I like about a LP with 4 Knobs.
Twww.sonnywalton.com
Well, whatever I do I would need to go bigger than an 047uF. It's bright enough as it is and that's with an 8K Plain Enamel HB in the neck position.
I have some .01 orange drops, I may try that or just leave it as it is and roll off the tone a bit.
I was mistaken about the Duncan Designed HB, it does have a fence on the base plate but everything about the pickup is just so cheesy and it shows in the sound.
T
The Russian PIO .022 caps are getting hard to find & quite a bit more $$$
Nice guitar Stratz
Any one winding today ?"UP here in the Canada we shoot things we don't understand"
Originally posted by copperheadroads View PostI stock sets of Russian PIO caps .015 for the neck & .033 for the bridge & at a reasonable price
Nice guitar Stratz
Working on some bobbins, and getting ready to order some mojo parts.
BTW Got an email that Remington is carrying some pickup tape, and some hookup wire.
It looks like stuff they are getting from mojo.
It is on their FleaBay store.
The russian caps I've seen are all metal and so damn big.
I think I'll stick with disk, and mylars.
Terry
Originally posted by Stratz View PostWell, whatever I do I would need to go bigger than an 047uF. It's bright enough as it is and that's with an 8K Plain Enamel HB in the neck position.
Does anyone know where he can get a replacement Hum Bucker?
Terry
Nice guitar Stratz
Any one winding today ?www.sonnywalton.com
Originally posted by copperheadroads View PostThat's cool
They need to carry pushback cloth & braided wire
Who ever tries the humbucker hookup wire please post a review
I guess I could ask them where the got it"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
