the replacement poles werent stainless were they? try the allthread like I mentioned but I have found black oxide works fine- could be a different alloy than what I get though. If I was replacing select poles in an old one I would use allthread and slot the ends.
Other than that Like I said the one magnet version doesnt work very well. Call my shop and order a set of new magnets, mine are usually stronger unlike the really inconsistant originals so you really have to replace both. They are somewhat expensive because they all custom made and have to be machined with the two slots but youll have a kick ass pickup after that- if you do that replace the poles with all black oxide or allthread and that will be the end of it. Maybe check to make sure your pickup reads about 6K. be carefull pulling poles in and out- the original bobbins are made quite fragile where the poles pass through
