Hello,
I have a pickup from a Washburn Wing series Falcon. It looks just like a Dimarzio, as it has pole pieces with the allen head adjustments. It also looks similar to a Strat humbucker. I will not be able to photograph it as, my camera will not upload at the present time.
The problem is that the pickup has only three wires in a shielded cable, shielding is wired to ground. The color of the wires is as follows Red, Blue, White, and the cable shielding.
The pickup is also controlled by a push pull pot, one click makes it single coil, next click humbucker.
When I use my meter it reads 3.7 on the blue and white, but nothing else on any of them. Could the red wire be a coil tap ?
