My Guitar Pedal does not work in 220v country
  • My Guitar Pedal does not work in 220v country
    Hi,
    I just moved from the states to Indonesia which is using 220v outlet, i brought all my guitar equipment that i bought from United States. my problem is when I tried to play my guitar with the pedal, the clean sound is weird, kind of like low battery sound on the delay pedal. and i am not using battery at all, i am using a vodoo lab power suply. there is no problem at all if i connected my amp to my guitar only and also if i turn on my distortion pedal, the sound is normal. first, i thought it was because my converter does not have enough watts, so i bought another 300 Watts converter and seperate the amp and the vodoo power supply, yet the sound still the same. here are the list of my pedal board from amp--->boss delay dd7-->volume pedal ernie ball-->echo booster exotic-->tube screamer ibanez-->maxon sonic overdrive-->budha wah pedal. all connected with voodo power suply. i also tried to not use the voodo power suply the sound is still the same. thank you in advance for the help
holiganbet betturkey
