Obsolete op amp?
Geez the day when the TL072 goes out of production will be earth shattering for guitar amps and effects
No Schematic….
Originally posted by olddawg View PostAre you missing the negative rail and have no regulation on the positive rail? Schematic?
Leave a comment:
Originally posted by mwint50 View PostThanks OC. Your a bloody ripper mate! (just kidding).
km6xz - I took voltages and they are as follows
1=0
2=0
3=0
4=0
5=0
6=0
7=0
8=17.35v
Leave a comment:
1=0
2=0
3=0
4=0
5=0
6=0
7=0
8=17.35v
Leave a comment:
Geezz another bloody Auzzie .. as above "ANY electronics parts house will have it" like
TL072/LF353 Dual Low Noise JFET Op-Amp Linear IC | Jaycar Electronics
and
Tl072cn Ic | Wagner Online Store
and
TL072CP | Texas Instruments TL072CP, Dual Op Amp, 3MHz, 8-Pin PDIP | Texas Instruments
finally
from this site it seems ST Microelectronics no longer make the 8pin version only the tiny surface mount one.
Just an observation as your one is made by ST ... any TLO72 is fine the trend these days is to make them so small
the old wave of techs cant see them !!
TL072IN - STMICROELECTRONICS - IC, OP-AMP, 4MHZ, 16V/ us, DIP-8 | element14 Australia
Leave a comment:
ANY electronics parts house will have it, the most common general purpose dual op amp available. Agree, check the voltage on each pin and list it here by pin number. Pin 1 is the one with the dot.
1o 8
2 7
3 6
4 5
Leave a comment:
Thats great news. Does Maplin have a reseller in Australia. Thanks so much for your reply!
Leave a comment:
Hi Mwint50 +welcome..... you're in luck still in production
TL072CN | Maplin
What makes you think it's fried?
Measuring each pin of the IC with a multimeter set to measure DC with the negative probe on
the main ground or chassis.
Pin 1 is beside the dot and count anti clockwise. (pin 8 is opposite)
Leave a comment:
Obsolete op amp?
Hi folks. Before I begin I am a complete amplifier amateur. I learn by trial and error and helps from others. Always have.....that said.....
I have, I believe, a fried op amp preventing my preamp from passing signal to the power amp stage of my guitar amplifier.
This exact IC seems to have gone the way of the dinosaurs. How would I begin to decide what would be a suitable replacement?Tags: None
Leave a comment:
