You have the rear channel switch set to 4 ch.? It has been cleaned?
You have the mode switch set to 4ch discrete? It has been cleaned?
Which set of inputs are you using?
If you are not sure about what the different terms mean, or which connections to use, here is a link to the operators manual:
https://www.manualslib.com/manual/35...75.html#manual
Leave a comment:
