I need the Best Cap I can find for a Reactive Load Powe Tool
+3 on the probability that a polarized capacitor was mistakenly put in there. As noted, a 32uf (ish) 100V NON polar cap should be used.
- Likes 1
Maybe it's 32uf 100V. The best cap isn't necessarily the most suitable and you may have space constraints. If not my choice for 'best' would be to use one or more 450v film motor capacitors to make up the required value. Fit and forget.
- Likes 2
Leave a comment:
IF there's enough space in there, substitute a film cap of similar value. Parts Express has their "Dayton" house brand caps intended for hi power speaker crossovers - recommend you check their catalog.
- Likes 2
Leave a comment:
Schematic?
Gut pictures?
I guess it was a 32uF *non polar* cap, if somebody substituted a plain electrolytic, it will die quickly.
No such a thing as a32UF 100watt cap
maybe that means something
- Likes 1
Leave a comment:
Without more details this is just a guess, but I would wonder if the original was a bipolar/nonpolar electrolytic, and the tech mistakenly replaced it with a standard polarized electrolytic?
Do you have the original cap? Or a photo of the circuit board?
- Likes 1
Leave a comment:
My 1994 PS Systems Power Tool input cap is badI had a guy put a new one in But it was a IC and when bad in a few weeks The output from my 100 watt Plexi goes into the 8ohm input and sees a 32UF 100watt cap Who makes a really good cap to take that The Old one when I first got it I think was a Atom and It lasted for years What do you think can Handle that thanks DABTags: None
Leave a comment:
