Help to check LFO section
  • Help to check LFO section
    Hello,
    I've just finished the build of a Stereo Chorus unit.
    http://jhaible.com/legacy/subtle_cho...le_chorus.html
    And I need to check if the LFO section and mode selection switch works properly, because I don't hear any changes between modes. When I change the mode I hear more "emphasis" on the effect. I attach a video. I don't think this sound is normal at all.
    I inject 1khz to the input.
    https://vimeo.com/773924317
    I attach a the LFO section and the rotary switch wiring section.
    Anybody can help me? please?​
    https://i.postimg.cc/crwmrwCw/subtle...d-sch-dwg1.png
    https://i.postimg.cc/PL9pWVFx/sc-wir...and-bypass.jpg
    https://i.postimg.cc/rDYKTYTJ/20221122-221925.jpg
    Maybe use a square wave test signal, as this doesn't contain only one frequency.
      This is with a 40hz square wave.
      https://vimeo.com/775060818
        Sorry, don't like to register. So can't see the vid.
        Why 40Hz? Thats too low for guitar and guitar speakers. I would use 400Hz.
            Ok, no modulation.
              Ok, no modulation.
              no,
              the bbd's works fine with another chorus. I have a problem somewhere...
                Do you have a pulsing voltage at both pins 1 of U3A (Schmitt trigger) and U2A (integrator)?
                  Main Board ( vintage build )
                  MC1458 U3A:
                  pin 1: 14,26V
                  TL082 U2A:
                  pin 1: -13,72v
                  no pulsating
                    Are +/- supply voltages good at pins 4/8?
                      yes,
                      pin 4, -15v and pin 8, +15v on both ic's
                        One of these opamps might be bad.
                          I have a TL062. I will try.
                            Replaced the MC1458 U3 with tl062 and now I have pulsating in pin 1 of TL082 U2A but fixed voltage on pin 1 of the tl062 U3.
                              https://www.youtube.com/watch?v=G6ExrmwIN4s
                              what do you think now?
