HP 6227B power supply - can't adjust current on right channel
  • HP 6227B power supply - can't adjust current on right channel
    Hi all,
    Got a used HP 6227B power supply yesterday.
    I went throught the Turn-On Checkout Procedure (page 3-1) and can't adjust the current on the right channel higher than 0.4A.
    https://xdevs.com/doc/HP_Agilent_Key...%20Service.pdf
    Any ideas of where the failure could be? Everything else works fine.
    Depending on what the failure is, I may just end up sending it back to the seller? It *is* a really nice power supply, otherwise.
    Cheers,
    Chris​
