Summer Fund Drive:C'mon guys lets show some support! If this site has helped you an you haven't recently donated Include your username so I know whos donatingPlease consider making a donation. :)
Thank you for your response. While i was trying to reset the amp, or remember the code, I looked up the manual and it listed what you said. However that does not reset the passcode, it only resets the all the digital amp sounds to the factory presets.
I ended up getting lucky and randomly put the correct code in. This allowed me to play the amp as normal.
If you press the 3 and 4 button together and hold them down for 3 seconds it will flash the key pad, then you are able to enter a three digit key of your choosing.
Now i am bake to turn on the amplifier and the key pad will flash waiting for the three digit code i chose...then the rocking begins!
I know this docent help if you don't know the code but once you get in it will allow you to change it to something you will remember.
Hello...I noticed that you have a schematic for the DX212. When I tried to open the file nothing was there. Is there a way I could get that from you? It would be much appreciated!
gud day steve, thank you for posting crate dx 212 schematics, but unfortunately i can't open the power amp section, will you pls send me a copy of the amplifier section? thank you so much
