Kurzweil PC88/mx
  • Kurzweil PC88/mx
    I contacted Kurzweil and got no reply (yet). Anybody have a schematic for one of these? I have one with no/low output.
    Used to have that one, but not now. Call them on the phone.
      Called and got voice mail- left message. Emailed- no reply. I will certainly keep trying, but I thought in the mean time......
        I have these PDF's listed as the PC88 manual, hope this helps:
        Drewline
        When was the last time you did something for the first time?
          Drewline,
          Firstly, thank you so much for the uploads. I'm in the middle of an all day recone project, so I will have a good look at those as soon as I get a second. I took a quick glance through them and don't see the portion I need which is the I/O board. I have traced signal on to that board, so I believe it's somewhere there- possibly a muting circuit since all op amps and transistors appear to be good. Without a schematic, I'm not sure what's supposed to happen, so I've been trying to decipher the circuit without one. The info I need may well be in your uploads and I just missed it in my quick scan. There is a troubleshooting guide in the PC88 SM, so I'll take a run at that. Again, thank you!
            I'm not sure what the second half of the PC3 manual is doing with the PC88 manual, but I'm attaching the first half here in case it might be of some help. In any case it gives you the entire PC3 manual.
            PC3 Series Service Manual Ver10 Part1.zip
            Drewline
              PC-88.zip
              I finally got it from Kurzweil. Posting here in case anyone else is looking for it.
