Ibanez help needed
I've had good luck with plain Alpha pots if that's all you can find. Bourns makes better pots for just a little more money and they have distribution in Denmark, though you may have to order them. Bourns has a special line of "guitar pots" that have lower torque, more refined tapers and are more likely to actually measure just an ohm or two at full rotation. I (personally) would change to audio taper pots for both controls.
Okay so, I had a look at it this weekend and luckily it seems like the guy didn't mess up the guitar so badly after all.
The volume pot-meter does not seem to work properly though - and I wasn't able to fix it with what would directly translate from Danish to English "Contact spray" (kinda like WD40 for electronics). The pot-meter is much easier to turn, but the problem remains: It is not able to turn the volume down to 0 and thus make no sound.
I had the pot-meter measured and it did have, like, 40 Ohms over it when turned down all the way.
If I were to change this pot-meter, would I need it to be a special kind of brand? Or is a cheap one from China okay?Last edited by big_teee; 04-01-2019, 01:52 PM.
Leave a comment:
He's even reliced himself.
Leave a comment:
Originally posted by Chuck H View PostI read an article about how the whole relic'd instrument thing started. Fender says they were making signature guitars for Keith Richards, but he wouldn't play them on stage. He said it felt wrong playing shiny new guitars on stage and asked them to "bash 'em up a bit" It wasn't long after that Fender decided to market the idea.
Leave a comment:
Indeed! Never a fan of the idea myself. The most absurd of it is special oxidizing treatments sold just for messing up your hardware "correctly". Or even faux oxide rusty colored finish you can rub around on your metal parts. And the most offensive of it is the crappy finishing done to instruments that will be relic'd. Not at all what a real vintage instrument started with. Looks more like it was done with rattle cans in the yard. Making me think the whole trend is just a way for manufacturers to charge more for LESS artistic work.
Truthfully I have no trouble relic-ing my own instruments, thank you.
Leave a comment:
Originally posted by J M Fahey View PostI relicīd my cool vintage Mercedes 190 SLX to increase buyerīs interest but somehow it isnīt working as expected
Iīll buy a gallon of nail enamel , that should do the trick.
Leave a comment:
Leave a comment:
Leave a comment:
Well, some think rust adds "character", go figure
In any case they wonīt affect sound.
I suggest you leave as is, just cover rusting metal (including the rusted part) with a coat or two of transparent nail enamel, toprotect it from ambient air and humidity.
Leave a comment:
Thank you so much for your help everyone!
With the schematic in place I will do my best at repairing my boyfriend's guitar!
A little extra question:
Is it possible to de-rust the pickups or should he get new ones if they're too rusty?
Love to all of you amazing people,
Sus
Leave a comment:
Originally posted by eschertron View PostThe IMGUR post shows what looks like a standard HSS strat, but with a funny red button on the upper bout? Is there any text/label showing what that does? Is there a control cavity behind it?
Carry on!
Leave a comment:
In case there is any confusion, here is the actual schematic from Ibanez for the GRX40. It does differ slightly from vintagekiki's posted schematic because of the pickup construction. The 331 capacitor would be 330pf and the 223 capacitor would be .022uf
Credit goes to g1 and Jazz. I was able to ID the guitar because of g1's photo request and I used Jazz's links to find the schematic.
Leave a comment:
Leave a comment:
Donīt worry about "different brand - different model", the schematic wiring shown above is "universal" and will work fine with your guitar or any other with the same pickup configuration.
That said, a couple pictures will help us know we are all talking the same.
Such as: full guitar, headstock, pickups/controls closeups for model identification.
Open circuit cavity, showing wires, switch, pots, jacks.
For closeups, maybe an old but "real camera" you have gathering dust on some closet will give better sharper pictures than a cellphone, since the latter are optimized for 1 to 4 meter away portraits and not that much for 30/40 cm away pictures, but hey, any picture is better than nothing.
As suggested above, upload them to some picture holding site and post links here we can open and see.
Leave a comment:
Leave a comment:
