Results 1 to 26 of 26
Thread: help with shielded input wiring hell
  1. #1
    Supporting Member
    Join Date
    Mar 2017
    Location
    Massachusetts, USA
    Posts
    1,310
    Thumbs Up/Down
    Received: 127/0
    Given: 2,037/0
    Rep Power
    4
    I got this Mogami shielded wire, for the amp inputs. It has really thin conductor, like about 5 human hairs, can't remember the gauge, 26 or thinner maybe.
    So, I strip and wrap the wire on, say, the input jack loops and apply a little bit of solder. So far so good. But when I fiddle with something in the amp, changing some part, whatever, it only takes a couple of REALLY small movement on the wire before the conductor snaps off, right at the place where the solder wicks down the conductor. It happened when I took the jacks out a few times, then 3 or 4 times for other repairs/mods. Just happened again.
    What type/gauge shielded wire do you all use? Is it OK to use thicker wire, like guitar cable, that has thicker conductor? I found some shielded wire with I think it was 20ga. I am not quite ready to toss the amp out the window, but the aggravation level for this input wiring breaking is quite high at this point.
    0 Not allowed! Not allowed!
  2. #2
    Join Date
    Aug 2015
    Location
    Edmonton, AB
    Posts
    237
    Thumbs Up/Down
    Received: 217/3
    Given: 111/3
    Rep Power
    4
    I have a spool of that Mogami wire.
    I make the inner conductor (with insulation) a bit long, then anchor the thing with the shield relatively short.
    This makes the inner form a small loop.
    The shield then takes the strain.
    On the end with the un-terminated shield, I find a way to anchor the cable somehow,
    so there is as little movement as possible on that fragile inner conductor.
    Some locations require some creative way to lay the wire so I can anchor it, and have a small loop on the fragile connection.
    HTH
    Edit;
    The alternative is some RG-174 co-ax.
    The inner conductor has some steel in it.
    Can be hard to solder, but the wire is much stronger.
    Edit;
    Ooops, my bad, it's the outer shield that is steel,
    but the inner strands are much thicker and stronger than the Mogami.
    2 Not allowed! Not allowed!
    The world is full of people that are right.
  3. #3
    Supporting Member eschertron's Avatar
    Join Date
    Aug 2012
    Location
    Great Black Swamp
    Posts
    2,148
    Thumbs Up/Down
    Received: 346/0
    Given: 872/1
    Rep Power
    9
    I've run into wire like that. So how much of this wire do you have? Too much to throw it all out?
    Making a pigtail as described above is a classic solution, or realize that this wire gives you one chance to get it right, and any tweak that involves moving it will involve replacing it.
    This doesn't help, but I've had good luck with a mic cable rated for wireway, i.e., it doesn't have a heavy rubber jacket, just the PVC. Branded by Horizon, 22 gauge with 7 conductors. And yes, the strands are stiff enough to not flex repeatedly at one point. I think the cable itself is designed to not be very flexible, because of the intended use in wireways.
    1 Not allowed! Not allowed!
  4. #4
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    1,531
    Thumbs Up/Down
    Received: 1,131/1
    Given: 690/2
    Rep Power
    4
    Edit;
    Edit;
    The RG-174 I have used had copper plated steel strands in the inner conductor - not in the shield.
  5. #5
    Join Date
    Aug 2015
    Location
    Edmonton, AB
    Posts
    237
    Thumbs Up/Down
    Received: 217/3
    Given: 111/3
    Rep Power
    4
    Hmmm, that could be...
    I do know that the rg-174 I have, the shield is difficult to solder, and very stiff.
    Come to think of it, the inner core is quite stiff as well, but copper colored.
  6. #6
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    1,531
    Thumbs Up/Down
    Received: 1,131/1
    Given: 690/2
    Rep Power
    4
    Quote Originally Posted by galaxiex View Post
    You can find out using a strong magnet.
  7. #7
    Old Timer Leo_Gnardo's Avatar
    Join Date
    Sep 2012
    Location
    Dogpatch-on-Hudson
    Posts
    5,994
    Thumbs Up/Down
    Received: 1,064/15
    Given: 1,011/0
    Rep Power
    12
    I have some of that stuff, left over from an ion implanter installation I helped with many moons ago. Very handy.
    A few years ago I got a call from up Schenectady way. An old GE engineer wanted his amps worked on. He asked me if I'd be interested in some special RG-174 that was made with all copper, no steel. Meant for use inside MRI machines. Well of course! What a treat that would be - but he never did show up, drat. But now we know that stuff exists, it's just where do you get it?
    3 Not allowed! Not allowed!
    Enjoy. Every. Sandwich.
  8. #8
    Supporting Member
    Join Date
    Mar 2017
    Location
    Massachusetts, USA
    Posts
    1,310
    Thumbs Up/Down
    Received: 127/0
    Given: 2,037/0
    Rep Power
    4
    Thanks everyone! Well, I only had a few feet of the really thin, thin stuff. The Mogami 2330 is 29 awg inner conductor, just looked it up. Eeek. No wonder my klutzy self could not work with it. Thanks for the tips, but I think I don't have the skills for this stuff.
    Their 2524 cable basically looks like standard guitar cable. The inner conductor is 20ga. I think I can't klutz that up. Capacitance is higher, 45pf /foot vs 36pf/foot, but its probably less than 1/2 a foot from the jacks to the tube socket pins. I don't think the extra 5pf will kill anything, from what little I know and since there will be an inch or so stripped, capacitance is probably lower than 5pf or so, total. (Rationalizing to myself why I should not improve my skills rather than ditching and running to auto jumper cables for the task) And there's plenty of room under the fiberglass turret board in this amp.
  9. #9
    Supporting Member
    Join Date
    Mar 2017
    Location
    Massachusetts, USA
    Posts
    1,310
    Thumbs Up/Down
    Received: 127/0
    Given: 2,037/0
    Rep Power
    4
    For Fender style amps, the input jacks are not isolated, so the ground right to the front panel on the chassis. The conductors go to the jack tips, of course, but should the shield pig tail just go to the ring lug on the jacks, so the shield grounds to the front plate as well? I read in multiple places, I think here on MEF, that the shield should get grounded at the input jacks and not near the tube socket side. (Don't know where my vintage fenders were grounded, but I do remember hearing "Tie A Yellow Ribbon" song from an AM radio station on that amp. I think it was WEOK).
  10. #10
    Join Date
    Aug 2015
    Location
    Edmonton, AB
    Posts
    237
    Thumbs Up/Down
    Received: 217/3
    Given: 111/3
    Rep Power
    4
    Yes, the inner conductor is indeed, very slightly magnetic.
    Also the outer shield.
    I used a very strong rare earth magnet to check.
  11. #11
    Join Date
    Sep 2012
    Location
    Dogpatch-on-Hudson
    Posts
    5,994
    Thumbs Up/Down
    Received: 1,064/15
    Given: 1,011/0
    Rep Power
    12
    Quote Originally Posted by mikepukmel View Post
    Looks like the right approach. And WEOK, yeah they would be playing an old chestnut like Tie a Yellow Ribbon, music for the over 90 crowd. Turn up your hearing aids kids!
    Years ago I bought a roll of some white Belden coax, very thin & flexible. But soldering that center conductor, jeeze you just look at that and it breaks, phooey! You can see why I was lusting after no-steel RG-174. Even with the steel, it's OK in guitar amps. It sure would raise hob in an MRI what with the super intense magnetic fields, I can imagine harnesses whipping around like crazed snakes on a Red Bull jag.
  12. #12
    Supporting Member
    Join Date
    Mar 2017
    Location
    Massachusetts, USA
    Posts
    1,310
    Thumbs Up/Down
    Received: 127/0
    Given: 2,037/0
    Rep Power
    4
    Update: well the stuff I had bought (thicker stuff) was actually 2 conductor. it has I think 22 ga innards, so was easy for a klutzy type to wire it up to the inputs. Turned out better than I thought it would, appearance wise anyway. That left the wiring to the volume controls from the tube pins. I bit the bullet, wired up the thin stuff that was there, REALLY carefully stripped the wire twisted it and just put a teeny bit of solder, and its on there now. Amp seems to still work and sound OK so I didn't do anything really stupid (at least for this repair). Thank GOD these amps are not as sensitive as MRI machines!
    Made permanent some previous ground wire re-routing, soldered and screwed a lug to the nice steel chassis. neatened up the grounds on the pot side of the preamp.
    All that's left to do now is debug a ringing in the reverb. When I turn the pot up beyond a point that I would never use it anyway (like 6 or7), a ringing right in the audio band starts up and SLOWLY gets louder and louder until I turn the pot back down.
  13. #13
    Supporting Member
    Join Date
    Mar 2017
    Location
    Massachusetts, USA
    Posts
    1,310
    Thumbs Up/Down
    Received: 127/0
    Given: 2,037/0
    Rep Power
    4
    Got the input wiring all redone, thanks for the help. It's close, but I think there's still a slight hum. I narrowed it down to this gain stage.
    6 Not allowed! Not allowed!
  14. #14
    Join Date
    Aug 2015
    Location
    Edmonton, AB
    Posts
    237
    Thumbs Up/Down
    Received: 217/3
    Given: 111/3
    Rep Power
    4
    I'm sure you could buff that out....
  15. #15
    Join Date
    Feb 2010
    Location
    Posts
    11,322
    Thumbs Up/Down
    Received: 1,283/21
    Given: 3,195/8
    Rep Power
    22
    That's funny. Let's see it in all it's glory.
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  16. #16
    Supporting Member
    Join Date
    Mar 2017
    Location
    Massachusetts, USA
    Posts
    1,310
    Thumbs Up/Down
    Received: 127/0
    Given: 2,037/0
    Rep Power
    4
    got a brand new gallon of heavy compound just inching to do some work!
  17. #17
    Supporting Member
    Join Date
    Mar 2017
    Location
    Massachusetts, USA
    Posts
    1,310
    Thumbs Up/Down
    Received: 127/0
    Given: 2,037/0
    Rep Power
    4
    Quote Originally Posted by g1 View Post
    Im thinking it's the negative feedback circuit. Dang negative feedback. Notice Im using carbon com's for that little added extra 'grit'.
  18. #18
    Join Date
    Jan 2014
    Location
    Chiraq
    Posts
    969
    Thumbs Up/Down
    Received: 184/5
    Given: 195/1
    Rep Power
    6
    looks like real engineering genius aka real trainwreck mojo. this picture can't be real??? is it?
    "persistence of man," comes to mind. great stuff
    also aside, waht are the ACTUAL values of all those carbon comps ? how much mojo can you really dial in? I'm not saying you can't make it sound better and better with more tweaks, but it seems funny to tweak something to such an extent, yet all the resistor component values are the least reliable values becasue of them being carbon comp.
    I know in my experience 1.5K cathode resistor vs 1.8K is a big change in sound. in a build I once put 1.6K cathode resistor in two gain stages because i was out of 1.5K. later on (months later) I played the amp again and thought it sounded nasally and a bit more thin sounding compared to other same amps. Opening it up, I noticed the 1.6k. Perhaps I heard waht I wanted, but changing both 1.6K cathode resistor to 1.5K was an easily noticeable improvement as far as what I expected/preferred it to sound like. I don't think I was "wanting to believe," I think it really was a big improvement. only so much more surprising because I thought the small change in component values would be inaudible. but anyway, is this picture real?
    Edit: obviously pic is real, BUT what i really wonder is is it a funny pic found online, or the real build under discussion
  19. #19
    Join Date
    Feb 2010
    Location
    Posts
    11,322
    Thumbs Up/Down
    Received: 1,283/21
    Given: 3,195/8
    Rep Power
    22
    Solid state devices are sometimes referred to as 'sand' (silicon). That might get you even more grit!
    You can make your own, this will get you started: https://www.popsci.com/diy/article/2...g-silicon-sand
  20. #20
    Lifetime Member Enzo's Avatar
    Join Date
    May 2006
    Location
    Lansing, Michigan, USA
    Posts
    31,598
    Thumbs Up/Down
    Received: 1,492/7
    Given: 0/0
    Rep Power
    54
    There were no bigger names in the analog field than Bob Pease and Jim Williams.
    Google
    "Bob Pease workbench" and "Jim Williams workbench" and see how actual engineers actually work.
  21. #21
    Old Timer
    Join Date
    May 2006
    Location
    Chill-Ville, VA
    Posts
    2,998
    Thumbs Up/Down
    Received: 557/5
    Given: 1,014/9
    Rep Power
    16
    Quote Originally Posted by Enzo View Post
    Google
    All of a sudden I feel better about myself...
    Jusrin
  22. #22
    Join Date
    May 2006
    Location
    Cheshire, UK
    Posts
    2,084
    Thumbs Up/Down
    Received: 398/4
    Given: 227/0
    Rep Power
    16
    Quote Originally Posted by Justin Thomas View Post
    I thought mine was a well ordered chaos but now it looks like I'm OCD tidy.
    4 Not allowed! Not allowed!
  23. #23
    Supporting Member
    Join Date
    Mar 2017
    Location
    Massachusetts, USA
    Posts
    1,310
    Thumbs Up/Down
    Received: 127/0
    Given: 2,037/0
    Rep Power
    4
    For those builders who absolutely *must* have a scratch build.
  24. #24
    Supporting Member
    Join Date
    Mar 2017
    Location
    Massachusetts, USA
    Posts
    1,310
    Thumbs Up/Down
    Received: 127/0
    Given: 2,037/0
    Rep Power
    4
    Google
    Oh man, crying here ... "First Prize: Ugliest Desk" : https://www.electronicdesign.com/sit...ffice_Fig2.jpg
  25. #25
    Join Date
    Mar 2008
    Posts
    653
    Thumbs Up/Down
    Received: 59/0
    Given: 154/0
    Rep Power
    12
    Holly F..k! Man, this is really something....functional ? Seems like a hell of extreme point to point wirring. Expression of Agression. It clearly show how you Mogamy frustration transcend from You project. Very cool.
  26. #26
    Senior Member nevetslab's Avatar
    Join Date
    Apr 2010
    Location
    Burbank, CA
    Posts
    1,607
    Thumbs Up/Down
    Received: 535/1
    Given: 1,259/1
    Rep Power
    11
    I love it! The second chief engineer I learned from wired in this style in prototyping circuits. Low level SS circuits, running off +/-15V, and often would be changing parts with hands' on/powered up in the nest, which at that stage of my education freaked me out. When you get the circuit right, POT IT!! (encapsulate it)
Thread Information
Users Browsing this Thread
  1. Funky input wiring
    By hylaphone in forum Vintage Amps
    Last Post: 09-13-2015, 12:11 PM
  2. Various Tweed input jack wiring
    By EETStudent in forum Theory & Design
    Last Post: 04-14-2011, 07:11 PM
  3. Input Jack Wiring
    By j-stylez in forum Tweed Builders
    Last Post: 02-15-2010, 03:29 AM
  4. Input Jack Wiring
    By ajeffcote in forum Guitar Amps
    Last Post: 05-07-2008, 11:06 AM
  5. Wiring P90 using 2 cond w./shielded ground...
    By eblock in forum Pickup Makers
    Last Post: 08-17-2007, 11:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
