Originally posted by galaxiex
View Post
help with shielded input wiring hell
Originally posted by g1 View PostThat's funny. Let's see it in all it's glory.
looks like real engineering genius aka real trainwreck mojo. this picture can't be real??? is it?
"persistence of man," comes to mind. great stuff
also aside, waht are the ACTUAL values of all those carbon comps ? how much mojo can you really dial in? I'm not saying you can't make it sound better and better with more tweaks, but it seems funny to tweak something to such an extent, yet all the resistor component values are the least reliable values becasue of them being carbon comp.
I know in my experience 1.5K cathode resistor vs 1.8K is a big change in sound. in a build I once put 1.6K cathode resistor in two gain stages because i was out of 1.5K. later on (months later) I played the amp again and thought it sounded nasally and a bit more thin sounding compared to other same amps. Opening it up, I noticed the 1.6k. Perhaps I heard waht I wanted, but changing both 1.6K cathode resistor to 1.5K was an easily noticeable improvement as far as what I expected/preferred it to sound like. I don't think I was "wanting to believe," I think it really was a big improvement. only so much more surprising because I thought the small change in component values would be inaudible. but anyway, is this picture real?
Edit: obviously pic is real, BUT what i really wonder is is it a funny pic found online, or the real build under discussionLast edited by nsubulysses; 11-07-2018, 05:20 AM.
Originally posted by mikepukmel View PostNotice Im using carbon com's for that little added extra 'grit'.
You can make your own, this will get you started: https://www.popsci.com/diy/article/2...g-silicon-sand
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
There were no bigger names in the analog field than Bob Pease and Jim Williams.
Google
"Bob Pease workbench" and "Jim Williams workbench" and see how actual engineers actually work.Education is what you're left with after you have forgotten what you have learned.
Jusrin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Originally posted by g1 View PostSolid state devices are sometimes referred to as 'sand' (silicon). That might get you even more grit!
Originally posted by Enzo View PostThere were no bigger names in the analog field than Bob Pease and Jim Williams.
Google
"Bob Pease workbench" and "Jim Williams workbench" and see how actual engineers actually work.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Originally posted by mikepukmel View PostGot the input wiring all redone, thanks for the help. It's close, but I think there's still a slight hum. I narrowed it down to this gain stage.
[ATTACH=CONFIG]51023[/ATTACH]Last edited by catalin gramada; 04-22-2019, 01:39 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
