EL34 cathode biased question
  • EL34 cathode biased question
    Hello, I need a suggestion regards the value of resistor / cap for a quad of EL34 cathode biased, please. OT 1.9K, B supply 450V. Thanks
    Let me know if is possible th run it in common mode with a single big power resistor placed somehow external on a heatsink ? The PT spec rated as 400mA for HT winding.
    The data sheet says to use individual 465R cathode resistors for 2 x EL34 at 450V but that's with an Ra-a of 6.5k (3.25k for a quad). I think that with a 1.9k OT you'll be in for some crossover distortion and you can't increase the bias current to reduce it without over dissipating the tubes. I have a 30W 2 x EL34 amp running at 375V into a 4K OT. It's fine with either individual 300R cathode resistors or a common 150R resistor.
Name:	EL34 cathode bias.png
      A single, common, cathode resistor "smooths-out" possible conduction differences between the banked tubes (think "mean" value here), while separate cathode resistors can be individually "trimmed/optimized" to accomplish the same/better results.
        OR
        Be a "smarty trousers" and run
        330 Ohms with 220uF/63V bypass on each tube but instead of returning these to 0V then
        For each push pull pair add a common 68 Ohms unbypassed under the 330 Ohms to 0V.
        That introduces some "conduction balance" and is good to supress some odd order harmonic distortion because of the common mode feedback it introduces.
        Be careful that the common (to 2 tubes) 68 Ohms is on a push pull pair and not on 2 tubes on the same side of the push pull.
        And be aware that this is a "cork sniffer" HiFi trick. You may not want that in your Git Amp.
        Cheers,
        Ian
          Originally posted by Gingertube View Post
          OR
          Cheers,
          Ian
          Hmm I like the smell of cork. It reminds me of victory!
          Might have to try this one on my AC100 Vox. Long time ago, I ran separate cathode resistors & caps. This looks like an interesting variation. Thanx Ginger!
            OR
            Cheers,
            Ian
            Neat-o.
            You could take this a step further and make the shared 68 ohm resistance a 100 ohm power rheostat. It would only need to be a three watt wire wound pot (no bigger and not much more expensive than than a regular pot). That way you have an actual bias adjust and some balancing ability.
              If you want a Marshall sound you'll probably bias at 70%.
              You've got 450 V +B. So you want 156 mA total quiescent current for all 4 x EL34.
              From the following datasheet
              we get that you want the grids at about -28VDC.
              So 450-28 = 422.
              You want 422 volts across the EL34's and 28 volts across Rk.
              28 = Rk * 156mA
              Rk = 179,49 OHMs
              If you want individual cathode resistors, multiply by 4.
              And Bob's your uncle.
              Valvulados
                jmaf,
                A problem - the curves you are using are for a screen grid voltage of +250V.
                The data Dave H linked is more suitable in this case.
                The "rule of thumb" for the 3rd harmonic cancellation scheme is to use a common resistor equal to 13 to 15% of the single tube cathode bias resistor , hence 68 Ohms as nearest preferred value.
                There are idle currents of 2 tubes in that so it effectively is the same as 2 x 68 = 136 Ohms in each cathode (as far as developing bias voltage goes).
                465 - 136 gives me the 330 Ohms for the individual resistors as the nearest preferred value.
                That is how I arrived at the values in my post. The common resistor needs to be unbypassed. the individual resistors should be bypassed, 220uF is middle ground suggestion but certainly you could try 100uF or 470uF.
                Similarly - for EL84 amps (270 Ohms individual cathode bias is standard) I use 39 Ohms Common and 180 Ohms as the individuals to get an effective cathode bias resistance (per tube) of 258 Ohms
                I occasionally use 2 x 390 in parallel = 195 Ohms instead of the 180 for slightly colder bias.
                Cheers,
                Ian
                  jmaf,
                  Look again on the grid transfer curve I used!
                  Valvulados
                    Cheers,
                    Ian
                    More on that here: https://www.diyaudio.com/forums/tube...y-huey-46.html
