View Post
Ever wonder about the Sprague Atom controversy?
Originally posted by Chuck H View Postyes, looks like crap and I took some heat for admitting it here before.
Your choice to NOT flip that board could have added a year (or more) to it's reliability, for all we know.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostI blame a lot of the current fetishization of aesthetics (with regard to amp guts) on the diy builders with no electronics knowledge. It's much easier to obsess over the angle of a wire bend than to actually learn whether it is relevant, or even counterproductive.
It's easier for me because to date I've only worked on my own amps, and work they do. If you work fixing amps, you need to be aware of sniping that goes on if your work is brought to a tech who makes his living of criticizing others work, and redoes stuff that was perfectly fine the way it was.
This type of stuff has been done for years in many different repair areas, including automotive.
If it ain't broke, don't fix it is mostly (but not always) true, with the exception of something that is truly an accident waiting to happen like a part flopping around or a positive voltage lead almost touching ground.
Not having a resistor or capacitor with the exact same leads bent at a perfect 90 degree angle is not a problem of any sorts, IMHO." Things change, not always for the better. " - Leo_Gnardo
Originally posted by nosaj View PostWhat the heck is that?
nosajExperience is something you get, just after you really needed it.
Originally posted by nickb View PostAmpeg portaflex. The main triple filter cap had been replaced by a three radial caps siliconed and tywrapped to a bamboo cane. The cane was siliconed to the chassis. It was all loose and floating around.
Anyone knows you need to use hot glue for bamboo."Take two placebos, works twice as well." Enzo
Originally posted by SoulFetish View PostWhat I can't understand at all, is how any self respecting modern manufacturer sells an electrolytic with a temp rating of 65˚!!!
I would never spec a capacitor in an amplifier build with a capacitor temperature rating like that, particularly in a tube amp.
having said that, I really never see them fail. My observation working on amps that use atom filter caps is that they may actually be a pretty reliable cap.Juan Manuel Fahey
