I've built a small audio signal tracer to try and help me locate the problem and so far I can hear that the humming noise is coming straight out of pin 7 of U101, but it isn't coming out of 1, 2 or 3 so I don't think the humming is coming before the circuit. I swapped the IC out for good measure, but it made no difference.
Peavey Valve King 100 head
If the hum is not at pin1 but at pin7, it is either getting picked up by the tank (which will act like an antenna), or there is a ground fault.
Someone asked early 'how bad is the hum' but you did not answer. Later, I see you mentioned seeing others complaining about it on youtube.
They all have a certain amount of hum as you turn up the reverb (tank acting as antenna). If you have the normal amount that others are complaining about, that is probably the best it's going to be. Is there significantly more reverb hum than other of the same model?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Hey g1, thanks for the reply. The hum becomes intrusive above about 3 on the knob. I found the following video on youtube which shows a different Peavey model, but with a very similar symptom https://www.youtube.com/watch?v=Znx9y5JpAzs I've never had the pleasure of trying one of these heads out so I can't compare it, but I'm assuming that isn't correct operation. With only 8 parts around the output I suppose I could shotgun replace the lot.
The user in that video makes a critical error which means the video is useless. He does not plug anything in to the amp and play it.
We have no idea what kind of volume he is setting the amp to. Many amps will hum if you don't plug anything in and turn everything full up. For all we know, when we hear the hum in the video, he has the volume set so loud you could not sit in the room if you played guitar at that volume setting.
Plug a guitar into your amp. Turn it up to a fairly loud volume that you actually play it at. Slowly bring up the reverb level. Does the hum seem loud compared to the guitar sound?
Sorry to go through all this, but it seems you may not be familiar with the 'usual' level of hum from reverb.
We can't make any assumptions from a video that has no reference to the guitar sound at playing levels.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostThe user in that video makes a critical error which means the video is useless. He does not plug anything in to the amp and play it.
Put your meter on ACV and connect across the speaker. Unplug your guitar. Report the readings for low volume w/o revverb, high volume w/o reverb and high volume with reverb.
.Experience is something you get, just after you really needed it.
I'll get on that later and report back, I take it that's a reading without any form of signal?
Originally posted by nickb View PostNo signal, just hum (and noise).
Afterwards I feed a metronome signal through the amp after and listened to the reverb output on pin 7 of the opamp, I've realised I can't actually hear the reverb under the humming noise, although the source audio signal is there. If I tap the reverb tank I get a strong and clear spring clanging sound.
Originally posted by jondoe View PostIt read as 0.10 ACV at all positions of the volume/reverb as you requested.
So, the only question now is does the reverb sound normal otherwise?Experience is something you get, just after you really needed it.
Originally posted by nickb View PostWith just 0.1V hum and noise with all turned up I don't think you have a hum problem at all.
I really don't think this is operating as it should.
Looking over the responses in this thread it seems that it's all got very confusing. For example the hum with reverb up was just 0.1V but it then stated that it swamps the input signal, which at 100W, is tens of volts, even just 1 watt is almost 3 volts. Certainly there is a complication that this is intermittent and that means pain.
What I would do is apply a 1khz 100mV signal to the input, plug something into the return to kill the main output (or use a dummy load) and look at the signal on the cable on the input to the tank. If that was missing I'd check U101 pin 3 and then U101 pin 1.
Are you within driving distance of West Devon? I'd be happy to put it on the bench and take a look.Last edited by nickb; 02-03-2019, 04:14 PM.Experience is something you get, just after you really needed it.
Originally posted by nickb View PostLooking over the responses in this thread it seems that it's all got very confusing. For example the hum with reverb up was just 0.1V but it then stated that it swamps the input signal, which at 100W, is tens of volts, even just 1 watt is almost 3 volts. Certainly there is a complication that this is intermittent and that means pain.
What I would do is apply a 1khz 100mV signal to the input, plug something into the return to kill the main output (or use a dummy load) and look at the signal on the cable on the input to the tank. f that was missing I'd check U101 pin 3 and then U101 pin 1.
Unfortunately I'm several hours away from West Devon so I can't take you up on that generous offer, but thank you
Originally posted by jondoe View PostI think I'm confusing myself at this point I think it's best I start from the beginning, I'm going to order up some new 12AX7's as I'm using my known good spares, but I shouldn't trust them 100%. I do have a home made 50w dummy load clamped to my box steel workbench frame for a heat sink, I'll feed in a signal and see how it looks.
Unfortunately I'm several hours away from West Devon so I can't take you up on that generous offer, but thank youExperience is something you get, just after you really needed it.
Originally posted by nickb View PostI doubt you need more valves as there is no valve section that is unique to the reverb and further it just complicates things with more unknown changes. Please try the suggested tests and see what we get. It's important to realise that the signal level you get at those points does depend on the volume setting so make sure they are not at zero.
