What's going on?
Vibro Champ shows slowly rising DC voltage on pin 5 of the 6V6, that's where the output of the preamp comes in. DC is supposed to be blocked by a ceramic .02. I hooked up a meter, and powered up. As the amp sits, the DC voltage there slowly rises, starting out around 25 millivolts and gradually rising. When it gets to around 250-300, the 6V6 plate starts glowing a little and the famous hum begins. Ceramic caps are pretty stable, aren't they? Why would steadily rising DC appear at the 6V6 grid? If I shut down, wait 30 sec or so and start over, it behaves the same... starts out at 25 or 30 mv, settles down at around 500 after 2 or 3 minutes, after 15 or 20 minutes, it shows about 300mv and stays there.
Gurus - any clues?
Gurus - any clues?
