Bass Pot - AA764
  • Bass Pot - AA764
    Hi,
    Can somebody explain how the Bass Pot is connected in the AA764 Schematic.
    What is the middle terminal on the pot (wiper) connected too.
    Greg
    If you look at the layout on page two here http://www.schematicheaven.com/fende...a764_schem.pdf, it should make things clearer. There's actually no connection to the "top" of the pot. One .1uf connects to the middle and the "bottom" of the pot connects to the junction of the 15k mid resistor and .047uf cap. The other connection is left open. The pot, in this case, is used as a variable resistor.
    I assume you mean the aa764 Bronco/Champ/Vibro Champ.
      Thanks Jag,
      That's the way I thought it was suppose to be connected.
      Regards
      Greg
