Need Math Help
  • Need Math Help
    What is the formula for calculating the cathode resistance in a cathode bypassed amp?
    MikeY
    MikeY
    This may help.
    http://www.diyguitarist.com/GuitarAmps/PT-Biasing.htm
      Mike,
      Here's some info from Randall Aiken's site. I assume you're trying to calculate the exact frequency response of a stage for a particular value of bypass cap?
      Ray
      Cathode impedance (unbypassed cathode)
      • It can be shown2 that the resistance seen looking into the cathode (Rk unbypassed) is:
      • Rk' = (Rp+ra)/(mu+1)
        = (100K + 62.5K)/(101)
        = 1.61K
        Therefore, the total cathode resistance, or the output impedance if you take the signal off the cathode, is the parallel combination of the cathode resistance, Rk', and the cathode resistor, Rk, as below:
        R = Rk' || Rk
        = 1.61K || 1.5K
        = 777 ohms
        By the way, this is the resistance you use if you want to calculate the lower -3dB point of an amplifier stage due to the cathode bypass capacitor. Most people mistakenly use the cathode resistor and the bypass cap to calculate the -3dB point, but that is incorrect. Also, most people mistakenly assume the low frequency rolloff has a -6dB per octave rolloff down to DC. This is also not true, the actual response is quite different.
