Hi guys.
I am new to your group, but, I have a question that I hope someone can help me with.
I work for a rental house (Bauder Audio Systems) here in Philly. This Hot Rod Deville that I am working on has me stumped.
When the amp is on the drive channel, the amp starts to flutter on the output. If you have the driver pot turned all the way up, the flutter decreases in frequency. If you turn it down, it increases.
When the amp is in the clean channel, it is fine, until you turn the treble up to around 2 or 3 O'clock. (8 on it's scale) At that point, the amp goes into high oscillations.
I have gone though the schematic, and have replaced two DC blocking caps. C-2, and C-7. Thinking that they may have been leaking. Not so. I also lifted all of the high resistance resistors and measured them. All tested in spec. I removed and tested pot R-7 (Drive), and R-13 (Treble). Both are fine. I have re soldered a few traces that looked a little suspicious as well. The tubes have been tested and also replaced. To no avail.
I thought that it could be the power supply. I removed the tubes, and tested the output of the power supply. It was stable. At this point, I am at a loss.
Has anyone encountered this problem before? Any help, or direction at this point, would be most welcome.
Thanks.
Thanks.
