Peavey Classic 50/212 Lead channel volume
  • Peavey Classic 50/212 Lead channel volume
    Hi,
    I have a Peavey Classic 50/212. The lead channel is not as loud as it should be. I balance the clean and lead to be the same volume for clean and dirty rhythm. with Clean level on 5-6 and Lead channel with pre on 7 (for crunch) post on 10 - they are about the same volume. I've played another second hand Peavey classic in a shop which does not have this problem so there clearly appears to be a fault. Could it be a valve needs replacing?
    Many thanks.
    Certainkly possible, get a fresh 12AX7 and substitute it in each socket one at a time.
      Thanks Enzo much obliged I'll give it a go
        pre-amp Valve
        Hi Enzo,
        Thanks it was one of the pre-amp valves. I'm about to replace them all and the power amp valves, about time I got around to it. Do you happen to know if the Classic 50/212 is fixed bias?
        Thanks again,
        Harry
          It is fixed bias and it is not adjustable either.
