Hello I have a 50 Watt bassman Ten and a 135 watt UL Twin reverb and I wanted to see if I could combine these into a 135 Watt Bassman and a 50 Watt Twin? Would it be a really big project? or a simple switcharoo
Bassman Ten + 135 UL Twin into 135W Bassman and 50W Twin?
If the chassis are the same size then you can just switch them around, and you have a 135W Twin in a Bassman cab, and a 50W Bassman in a Twin cab. The remaining minor circuit changes are optional :-)
Otherwise it's a major job as you'd have to gut both chassis and swap the innards around. It would probably be better to sell both amps and buy what you really wanted in the first place."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
