Is this a safe swap assuming the bias is set for the KT66? thanks Bob
EL34 to KT66?
They should drop right in, aside from the bias setting. However, if you are looking for a drop-in beam tube replacement with similar bias settings, scope out either some NOS or E-H 6CA7's. In the "old days", 6CA7's were often labeled "6CA7/EL34", because even though they were/are different tube types (beam-tetrode vs. power-pentode), they had similar ratings and bias requirements.
Thanks. I wasnt sure if anybody was actually making real 6CA7's but I'd like to try them as well -for that matter Im not sure if anybod is making real KT66's either! lol! Bob"Reality is an illusion albeit a very persistant one " Albert Einstein
I'm almost positive that the E-H 6CA7 is a modified version of their 6L6GC, as the plate structure is identical. In any case, these can and do sub for EL34's directly, as I have done it here in the shop. "Real" KT66's? Not sure about that. A lot of reissued tubes are rebottled and/or repinned versions of more common types, e.g. 6550/KT88. "KT" or "Kinkless Tetrode" was/is a very specific, highly-linear design spec for beam-tetrode tubes, but I suspect that the new KT-xx tubes we now see are, as I said, just garden-variety beam-tetrodes.
Originally posted by defaced View PostJJ makes a E34L (6CA7). I've got a pair and am satisfied with them, but I think I'll end up switching them out for KT-88s.
Originally posted by jrfrond View PostI'm almost positive that the E-H 6CA7 is a modified version of their 6L6GC, as the plate structure is identical. In any case, these can and do sub for EL34's directly, as I have done it here in the shop. "Real" KT66's? Not sure about that. A lot of reissued tubes are rebottled and/or repinned versions of more common types, e.g. 6550/KT88. "KT" or "Kinkless Tetrode" was/is a very specific, highly-linear design spec for beam-tetrode tubes, but I suspect that the new KT-xx tubes we now see are, as I said, just garden-variety beam-tetrodes."Reality is an illusion albeit a very persistant one " Albert Einstein
