speaker load while testing tube voltages
  • speaker load while testing tube voltages
    Hi, group. I recently had a problem and I was told to remove the power tubes and check for voltages present. Whenever I blow a set of tubes, I usually run two tubes for a while until my replacement quad comes in, and I have to adjust impedance on back of the amp to compensate for pulling of the tubes.
    When I am measuring voltages inside the amp with no power tubes installed and with nothing plugged into the input, what kind of speaker load do I need to put on the amp?
    Thank you for any feedback.
    With no tubes you do not need a load. If you keep two working tubes in the amp you still need the correct speaker load or a dummy load of the same impedance.
      thanks alot
      Thanks alot Chuck. You never want to end up doing more damage than good. I always like to ask first before I get too carried away doing something different. Sort of the measure twice cut once kind of mentality. Thanks again for the feedback.
