Help! Soldering on a new board
  • Help! Soldering on a new board
    I'm having a hard time getting the solder to stick to the pads on my printed circuit board. The pads have a white film, which \i thought was ready to solder. But I've found a lot of cold solder joints after I started in.
    Does this white film need to be removed?
    OK. I think my iron wasn't hot enough to get the wire itself hot. It seems to be working now with the white stuff intact.
    I'm not familiar with this but my guess would be a wipe-down with acetone would take off any manufacturing residue or anti-corrosion goo.
    Check out my signal generator for your iPhone or iPod Touch.
      That and use a little liquid flux. Maybe even rough up the pads a little with a pencil eraser, matchbook cover, fine emory cloth, etc. Don't use steel wool unless it is a naked board and you can whipe it off afterward.
        soldering
        Make sure you have a good tip on your iron. Soap and water on the solder side have always worked fine for me with a toothbrush. Defintately make sure it is dry before applying any current to it of course. Alcohol and acetone as mentioned, are the only things I have ever used.
          I don't know about your boards, but some "bare copper" boards have a film over the copper, I guess to keep it shiny untik you buy it. This interferes with the soldering. The small "experiementer" boards I bought at Radio Shack were like this. I always sanded the boards copper side a little before soldering. Steel wool would work, but I don;t allow the stuff in my shop. I use Scotch Brite - the green plastic pads used like steel wool for cleaning pots and pans. It is abrasive enough for the job, but softer than the copper so it doesn;t sand through it. 400-800 grit emery cloth also would work.
            Thanks. I definitely will clean the next board. I had to go over each pad and heat it up again. I may have overheated a germanium diode that way.
            I have a nicer digital soldering station now, which helps keep the tip the right temp. What temperature should I be using for populating a brand new board?
