crackling noise when playing hard
  • crackling noise when playing hard
    fender pr-ll.
    makes static crackling noise when chord is strummed moderately hard.
    with bass control turned right down the noise is not noticeable...???
    Also as the power switch is switched off i hear a loud static crackle (there is no stand by sw.)
    Tried replacing all tubes and solder joints seem solid. Most resistors and almost all caps are new.
    WTF !
    Ha... seems I solved my problem 10 seconds after posting.
    Broken leg on the bass cap.
    Most of you probably would have suggested to check that cap... so thanks anyway.
